Bricked Wio Terminal
I bricked my Wio Terminal. Can’t get it into bootloader mode (has blinking blue LED when trying to use). Also my PC doesn’t get a Serial Connection or recognizes the device at all.
Does anyone know what i can do?
Hi @pale,
What can you see under Ports when you open Device Manager on your PC?
Best Regards,
Lakshantha
Hi, @lakshan
I had no reaction on the PC side. (Using linux and had no mention in dmesg at all)
Found out this problem to be similar to the one mentioned here. I got it solved the same way (connecting it to another machine) and it came back appearing in the Device Manager of win.
Thanks for your hint, also with linux it works again :slight_smile:
