Is it possible to restore the factory defaults?
If so how do you do it?
The Bluetooth Bee is base on firmware 2.0.
So about more Bluetooth 2.0 protocol you should check the datasheet.
Best regards,
Yuri
I also need to reset my Bluetooth Bee to factory defaults - I set the baudrate to 115200, but now all I get is garbled characters from the Bluetooth Bee. I have tried using each of the supported baudrates to no avail.
I checked the data sheet:
seeedstudio.com/wiki/images/ … asheet.pdf
But it has no information on resetting the Bee to factory defaults.
Can you help?
Adam F
