Yes it’s the same for both boards, I have tested it using:
- internal eMMC (on both)
- 64gb sandisk class 10 A1 microSD Ultra
- Generic 8GB microSD
It’s the same error for all of them (including, as I said above, even with a change in operating system).
This is a hardware fault.
dmesg screenshot:
dmesg text output (I cut the first few lines off, because this site has a 32k character limit and you can’t attach text files):
debian@beaglebone:~$ dmesg
[ … other boot up lines … ]
[    1.157090] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
[    1.160537] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    1.160580] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    1.160916] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.160927] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.160934] usb usb1: Product: MUSB HDRC host driver
[    1.160941] usb usb1: Manufacturer: Linux 4.19.94-ti-r42 musb-hcd
[    1.160948] usb usb1: SerialNumber: musb-hdrc.1
[    1.161760] hub 1-0:1.0: USB hub found
[    1.161823] hub 1-0:1.0: 1 port detected
[    1.173710] omap_rtc 44e3e000.rtc: registered as rtc0
[    1.175023] i2c /dev entries driver
[    1.178236] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.178808] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    1.183639] ledtrig-cpu: registered to indicate activity on CPUs
[    1.184299] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[    1.184637] omap-aes 53500000.aes: will run requests pump with realtime priority
[    1.187090] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[    1.190791] hidraw: raw HID events driver (C) Jiri Kosina
[    1.197771] gnss: GNSS driver registered with major 242
[    1.204460] NET: Registered protocol family 10
[    1.275821] Segment Routing with IPv6
[    1.276120] mip6: Mobile IPv6
[    1.276286] NET: Registered protocol family 17
[    1.276317] can: controller area network core (rev 20170425 abi 9)
[    1.276416] NET: Registered protocol family 29
[    1.276500] 8021q: 802.1Q VLAN Support v1.8
[    1.276578] Key type dns_resolver registered
[    1.276585] mpls_gso: MPLS GSO support
[    1.276894] ThumbEE CPU extension supported.
[    1.276909] Registering SWP/SWPB emulation handler
[    1.276919] omap_voltage_late_init: Voltage driver support not added
[    1.285248] registered taskstats version 1
[    1.285259] Loading compiled-in X.509 certificates
[    1.285389] zswap: loaded using pool lzo/zbud
[    1.288876] Btrfs loaded, crc32c=crc32c-generic
[    1.288988] AppArmor: AppArmor sha1 policy hashing enabled
[    1.341517] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[    1.342368] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[    1.343319] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    1.344336] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[    1.344447] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    1.346298] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 400 kHz
[    1.348116] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz
[    1.352718] cpu cpu0: Linked as a consumer to regulator.4
[    1.352825] cpu cpu0: Dropping the link to regulator.4
[    1.353319] cpu cpu0: Linked as a consumer to regulator.4
[    1.355388] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    1.356861] ALSA device list:
[    1.356872]   No soundcards found.
[    1.363105] Freeing unused kernel memory: 1024K
[    1.363828] Run /init as init process
[    5.997308] EXT4-fs (mmcblk1p1): INFO: recovery required on readonly filesystem
[    5.997323] EXT4-fs (mmcblk1p1): write access will be enabled during recovery
[    6.338100] EXT4-fs (mmcblk1p1): recovery complete
[    6.341463] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
[    6.858452] systemd[1]: System time before build time, advancing clock.
[    6.892186] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    6.892941] systemd[1]: Detected architecture arm.
[    6.911410] systemd[1]: Set hostname to .
[    8.168566] systemd[1]: /lib/systemd/system/rc_battery_monitor.service:5: PIDFile= references path below legacy directory /var/run/, updating /var/run/rc_battery_monitor.pid → /run/rc_battery_monitor.pid; please update the unit file accordingly.
[    8.290684] systemd[1]: Listening on fsck to fsckd communication Socket.
[    8.292351] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    8.293784] systemd[1]: Listening on Journal Audit Socket.
[    8.293953] systemd[1]: Reached target Remote File Systems.
[    8.294100] systemd[1]: Reached target Swap.
[    8.296315] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    9.617789] remoteproc remoteproc0: 4a334000.pru is available
[    9.617976] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[    9.621870] remoteproc remoteproc1: 4a338000.pru is available
[    9.622039] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
[    9.636278] EXT4-fs (mmcblk1p1): re-mounted. Opts: errors=remount-ro
[   10.590219] systemd-journald[486]: Received request to flush runtime journal from PID 1
[   21.713054] using random self ethernet address
[   21.713073] using random host ethernet address
[   22.294714] Mass Storage Function, version: 2009/09/11
[   22.294738] LUN: removable file: (no medium)
[   22.662779] using random self ethernet address
[   22.662798] using random host ethernet address
[   22.888310] usb0: HOST MAC f4:5e:ab:54:70:7a
[   22.892740] usb0: MAC f4:5e:ab:54:70:79
[   22.904065] usb1: HOST MAC f4:5e:ab:54:70:7c
[   22.904508] usb1: MAC f4:5e:ab:54:70:7d
[   23.156206] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[   23.358963] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[   23.396765] configfs-gadget gadget: high-speed config #1: c
[   23.397097] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[   23.422772] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[   31.720120] wlan-en-regulator: disabling
[   46.642444] remoteproc remoteproc2: wkup_m3 is available
[   46.850053] remoteproc remoteproc2: powering up wkup_m3
[   46.850086] remoteproc remoteproc2: Booting fw image am335x-pm-firmware.elf, size 217168
[   46.850553] remoteproc remoteproc2: remote processor wkup_m3 is now up
[   46.850575] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[   47.031270] PM: bootloader does not support rtc-only!
[   52.636340] Bluetooth: Core ver 2.22
[   52.636574] NET: Registered protocol family 31
[   52.636582] Bluetooth: HCI device and connection manager initialized
[   52.636611] Bluetooth: HCI socket layer initialized
[   52.636624] Bluetooth: L2CAP socket layer initialized
[   52.636691] Bluetooth: SCO socket layer initialized
[   52.712120] Bluetooth: HCI UART driver ver 2.3
[   52.712140] Bluetooth: HCI UART protocol H4 registered
[   52.712443] Bluetooth: HCI UART protocol LL registered
[   52.712453] Bluetooth: HCI UART protocol ATH3K registered
[   52.712585] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   53.640646] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   53.676815] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[   53.677205] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   53.677227] cfg80211: failed to load regulatory.db
[   53.947175] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   53.947191] Bluetooth: BNEP filters: protocol multicast
[   53.947224] Bluetooth: BNEP socket layer initialized
[   54.408199] Bluetooth: RFCOMM TTY layer initialized
[   54.408240] Bluetooth: RFCOMM socket layer initialized
[   54.408297] Bluetooth: RFCOMM ver 1.11
[   55.605226] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[   55.634247] wlcore: loaded
[   56.201078] wlcore: PHY firmware version: Rev 8.2.0.0.242
[   56.239431] wlcore: firmware booted (Rev 8.9.0.0.79)
[   56.255590] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   57.212405] wlan0: authenticate with 10:0d:7f:d8:f2:f0
[   57.222701] wlan0: send auth to 10:0d:7f:d8:f2:f0 (try 1/3)
[   57.252683] wlan0: authenticated
[   57.264083] wlan0: associate with 10:0d:7f:d8:f2:f0 (try 1/3)
[   57.268423] wlan0: RX AssocResp from 10:0d:7f:d8:f2:f0 (capab=0x411 status=0 aid=5)
[   57.285542] wlan0: associated
[   57.414076] cryptd: max_cpu_qlen set to 1000
[   57.466473] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   57.484755] wlcore: Association completed.
[   59.504234] IPv6: ADDRCONF(NETDEV_UP): SoftAp0: link is not ready
[   60.744935] wlcore: down
[   60.808689] IPv6: ADDRCONF(NETDEV_CHANGE): SoftAp0: link becomes ready
[   64.427992] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   67.873267] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   67.879454] mmcblk1: recovery failed!
[   67.884042] print_req_error: I/O error, dev mmcblk1, sector 3417088
[   68.181333] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   68.187510] mmcblk1: recovery failed!
[   68.191823] print_req_error: I/O error, dev mmcblk1, sector 5251136
[   68.198238] EXT4-fs warning (device mmcblk1p1): ext4_end_bio:323: I/O error 10 writing to inode 50466 (offset 0 size 4096 starting block 656393)
[   68.198257] Buffer I/O error on device mmcblk1p1, logical block 655368
[   68.204979] JBD2: Detected IO errors while flushing file data on mmcblk1p1-8
[   68.205037] Aborting journal on device mmcblk1p1-8.
[   68.216854] EXT4-fs error (device mmcblk1p1) in __ext4_new_inode:933: Readonly filesystem
[   68.542462] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   68.548707] mmcblk1: recovery failed!
[   68.552475] print_req_error: I/O error, dev mmcblk1, sector 3416064
[   68.558869] Buffer I/O error on dev mmcblk1p1, logical block 425984, lost sync page write
[   68.567226] JBD2: Error -5 detected when updating journal superblock for mmcblk1p1-8.
[   68.866726] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   68.872902] mmcblk1: recovery failed!
[   68.876631] print_req_error: I/O error, dev mmcblk1, sector 8192
[   68.882786] Buffer I/O error on dev mmcblk1p1, logical block 0, lost sync page write
[   68.891302] EXT4-fs (mmcblk1p1): I/O error while writing superblock
[   68.897768] EXT4-fs (mmcblk1p1): previous I/O error to superblock detected
[   68.904877] EXT4-fs error (device mmcblk1p1): ext4_journal_check_start:61: Detected aborted journal
[   69.204500] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   69.210675] mmcblk1: recovery failed!
[   69.214400] print_req_error: I/O error, dev mmcblk1, sector 8192
[   69.220475] Buffer I/O error on dev mmcblk1p1, logical block 0, lost sync page write
[   69.233284] EXT4-fs (mmcblk1p1): I/O error while writing superblock
[   69.244414] EXT4-fs (mmcblk1p1): Remounting filesystem read-only
[   69.250633] EXT4-fs (mmcblk1p1): Remounting filesystem read-only
[   69.555378] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   69.561574] mmcblk1: recovery failed!
[   69.565816] print_req_error: I/O error, dev mmcblk1, sector 8192
[   69.571919] Buffer I/O error on dev mmcblk1p1, logical block 0, lost sync page write
[   69.580269] EXT4-fs (mmcblk1p1): I/O error while writing superblock
[   71.508969] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   71.998556] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   81.718815] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   91.627565] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   92.073393] omap_hsmmc 481d8000.mmc: error -110 requesting status
[   97.834305] musb-hdrc musb-hdrc.1: VBUS_ERROR in a_wait_bcon (89, <AValid), retry #1, port1 00000104
[   97.881694] ------------[ cut here ]------------
[   97.881757] WARNING: CPU: 0 PID: 1323 at drivers/net/wireless/ti/wlcore/sdio.c:100 wl12xx_sdio_raw_read+0x14c/0x1b0 [wlcore_sdio]
[   97.881764] Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfcomm bnep cfg80211 hci_uart bluetooth ecdh_generic pm33xx wkup_m3_ipc wkup_m3_rproc wlcore_sdio usb_f_acm u_serial usb_f_ecm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio pruss_soc_bus pru_rproc pruss irq_pruss_intc remoteproc virtio virtio_ring spidev
[   97.881863] CPU: 0 PID: 1323 Comm: irq/85-wl18xx Not tainted 4.19.94-ti-r42 #1buster
[   97.881868] Hardware name: Generic AM33XX (Flattened Device Tree)
[   97.881913] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[   97.881938] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
[   97.881956] [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
[   97.881969] [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
[   97.881987] [] (warn_slowpath_null) from [] (wl12xx_sdio_raw_read+0x14c/0x1b0 [wlcore_sdio])
[   97.882293] [] (wl12xx_sdio_raw_read [wlcore_sdio]) from [] (wlcore_irq_locked+0x100/0x79c [wlcore])
[   97.882506] [] (wlcore_irq_locked [wlcore]) from [] (wlcore_irq+0x94/0x188 [wlcore])
[   97.882616] [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x2c/0x88)
[   97.882632] [] (irq_thread_fn) from [] (irq_thread+0x164/0x234)
[   97.882643] [] (irq_thread) from [] (kthread+0x16c/0x174)
[   97.882658] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[   97.882665] Exception stack(0xd5411fb0 to 0xd5411ff8)
[   97.882675] 1fa0:                                     00000000 00000000 00000000 00000000
[   97.882686] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   97.882695] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   97.882703] —[ end trace fe58a0b92171d6e9 ]—
[   97.882721] wl1271_sdio mmc2:0001:2: sdio read failed (-110)
[   97.888581] ------------[ cut here ]------------
[   97.888720] WARNING: CPU: 0 PID: 1323 at drivers/net/wireless/ti/wlcore/main.c:808 wl12xx_queue_recovery_work+0x64/0x68 [wlcore]
[   97.888728] Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfcomm bnep cfg80211 hci_uart bluetooth ecdh_generic pm33xx wkup_m3_ipc wkup_m3_rproc wlcore_sdio usb_f_acm u_serial usb_f_ecm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio pruss_soc_bus pru_rproc pruss irq_pruss_intc remoteproc virtio virtio_ring spidev
[   97.888810] CPU: 0 PID: 1323 Comm: irq/85-wl18xx Tainted: G        W         4.19.94-ti-r42 #1buster
[   97.888816] Hardware name: Generic AM33XX (Flattened Device Tree)
[   97.888841] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[   97.888860] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
[   97.888874] [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
[   97.888887] [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
[   97.888999] [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work+0x64/0x68 [wlcore])
[   97.889174] [] (wl12xx_queue_recovery_work [wlcore]) from [] (wlcore_irq+0x118/0x188 [wlcore])
[   97.889272] [] (wlcore_irq [wlcore]) from [] (irq_thread_fn+0x2c/0x88)
[   97.889285] [] (irq_thread_fn) from [] (irq_thread+0x164/0x234)
[   97.889296] [] (irq_thread) from [] (kthread+0x16c/0x174)
[   97.889307] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[   97.889314] Exception stack(0xd5411fb0 to 0xd5411ff8)
[   97.889324] 1fa0:                                     00000000 00000000 00000000 00000000
[   97.889334] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[   97.889344] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[   97.889350] —[ end trace fe58a0b92171d6ea ]—
[   97.889526] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.79
[   97.889552] wlcore: down
[   97.889596] wlcore: down
[   97.889611] wlcore: down
[   97.889904] ieee80211 phy0: Hardware restart was requested
[   97.902412] musb-hdrc musb-hdrc.1: VBUS_ERROR in a_wait_vrise (89, <AValid), retry #2, port1 00000104
[   98.324642] wlcore: PHY firmware version: Rev 8.2.0.0.242
[   98.372783] wlcore: firmware booted (Rev 8.9.0.0.79)
[   98.427547] wlcore: Association completed.
[   98.593981] musb-hdrc musb-hdrc.1: VBUS_ERROR in a_wait_vrise (89, <AValid), retry #3, port1 00000104
[  104.700879] omap_hsmmc 481d8000.mmc: error -110 requesting status
[  110.466611] omap_hsmmc 481d8000.mmc: error -110 requesting status
[  111.269054] musb-hdrc musb-hdrc.1: VBUS_ERROR in a_wait_bcon (88, <AValid), retry #3, port1 0008010c
[  113.676782] omap_hsmmc 481d8000.mmc: error -110 requesting status
[  115.779535] omap_hsmmc 481d8000.mmc: error -110 requesting status
[  120.647356] ------------[ cut here ]------------
[  120.647412] WARNING: CPU: 0 PID: 1457 at drivers/net/wireless/ti/wlcore/sdio.c:145 wl12xx_sdio_raw_write+0x148/0x1b4 [wlcore_sdio]
[  120.647418] Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfcomm bnep cfg80211 hci_uart bluetooth ecdh_generic pm33xx wkup_m3_ipc wkup_m3_rproc wlcore_sdio usb_f_acm u_serial usb_f_ecm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio pruss_soc_bus pru_rproc pruss irq_pruss_intc remoteproc virtio virtio_ring spidev
[  120.647518] CPU: 0 PID: 1457 Comm: kworker/u2:3 Tainted: G        W         4.19.94-ti-r42 #1buster
[  120.647523] Hardware name: Generic AM33XX (Flattened Device Tree)
[  120.647813] Workqueue: phy0 wl1271_tx_work [wlcore]
[  120.647861] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[  120.647887] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
[  120.647906] [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
[  120.647918] [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
[  120.647938] [] (warn_slowpath_null) from [] (wl12xx_sdio_raw_write+0x148/0x1b4 [wlcore_sdio])
[  120.648080] [] (wl12xx_sdio_raw_write [wlcore_sdio]) from [] (wlcore_tx_work_locked+0x750/0xf30 [wlcore])
[  120.648262] [] (wlcore_tx_work_locked [wlcore]) from [] (wl1271_tx_work+0x44/0xc8 [wlcore])
[  120.648362] [] (wl1271_tx_work [wlcore]) from [] (process_one_work+0x1b4/0x504)
[  120.648378] [] (process_one_work) from [] (worker_thread+0x60/0x508)
[  120.648390] [] (worker_thread) from [] (kthread+0x16c/0x174)
[  120.648403] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[  120.648411] Exception stack(0xdc5d9fb0 to 0xdc5d9ff8)
[  120.648422] 9fa0:                                     00000000 00000000 00000000 00000000
[  120.648433] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  120.648442] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[  120.648451] —[ end trace fe58a0b92171d6eb ]—
[  120.648468] wl1271_sdio mmc2:0001:2: sdio write failed (-110)
[  120.679293] ------------[ cut here ]------------
[  120.679605] WARNING: CPU: 0 PID: 1457 at drivers/net/wireless/ti/wlcore/main.c:808 wl12xx_queue_recovery_work+0x64/0x68 [wlcore]
[  120.679615] Modules linked in: xt_state xt_conntrack nft_counter nft_chain_nat_ipv4 ipt_MASQUERADE nft_compat aes_arm_bs crypto_simd cryptd wl18xx wlcore mac80211 rfcomm bnep cfg80211 hci_uart bluetooth ecdh_generic pm33xx wkup_m3_ipc wkup_m3_rproc wlcore_sdio usb_f_acm u_serial usb_f_ecm usb_f_mass_storage usb_f_rndis u_ether libcomposite uio_pdrv_genirq uio pruss_soc_bus pru_rproc pruss irq_pruss_intc remoteproc virtio virtio_ring spidev
[  120.679714] CPU: 0 PID: 1457 Comm: kworker/u2:3 Tainted: G        W         4.19.94-ti-r42 #1buster
[  120.679720] Hardware name: Generic AM33XX (Flattened Device Tree)
[  120.679846] Workqueue: phy0 wl1271_tx_work [wlcore]
[  120.679891] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[  120.679916] [] (show_stack) from [] (dump_stack+0x8c/0xa0)
[  120.679934] [] (dump_stack) from [] (__warn.part.3+0xcc/0xe8)
[  120.679946] [] (__warn.part.3) from [] (warn_slowpath_null+0x54/0x5c)
[  120.680057] [] (warn_slowpath_null) from [] (wl12xx_queue_recovery_work+0x64/0x68 [wlcore])
[  120.680237] [] (wl12xx_queue_recovery_work [wlcore]) from [] (wl1271_tx_work+0xc4/0xc8 [wlcore])
[  120.680338] [] (wl1271_tx_work [wlcore]) from [] (process_one_work+0x1b4/0x504)
[  120.680352] [] (process_one_work) from [] (worker_thread+0x60/0x508)
[  120.680364] [] (worker_thread) from [] (kthread+0x16c/0x174)
[  120.680377] [] (kthread) from [] (ret_from_fork+0x14/0x2c)
[  120.680385] Exception stack(0xdc5d9fb0 to 0xdc5d9ff8)
[  120.680396] 9fa0:                                     00000000 00000000 00000000 00000000
[  120.680406] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  120.680416] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[  120.680424] —[ end trace fe58a0b92171d6ec ]—
[  120.687968] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.0.79
[  120.688005] wlcore: down
[  120.688048] wlcore: down
[  120.688064] wlcore: down
[  120.689140] ieee80211 phy0: Hardware restart was requested
