Beacon FAILED from Gateway to LoRa E5 Dev board
I am new to LoRa and gateways. I have connected 3 LoRa E5 Development boards and 3 LoRa E5 MINIs to the ChirpStack Server using a Rak2245 Pi Hat gateway. I am able to send short Messages to the server by doing AT+MSG = “HI” e.g. However, what I want to do now is to ping from the gateway every second and receive a response in the LoRa boards and see it in the server as well. Does anyone have an idea of how to do this? Do I need to first program the boards instead of using AT commands?
I tried to do AT+BEACON, but it never finds a beacon from the gateway and it returns “+BEACON: FAILED”.
Thank you so much!
If I understand well what you want to do it’s not really allowed in Lora and not designed for that too ! You want each beacon to ping server and get an answer every second ? it’s just sont of non sense with Lora, it’s not designed like that :wink:
Hi @vincen,
Thank you so much for your reply! Sorry for my ignorance, can you explain how does the beaconing work then?
Thank you!
