BBG Getting Started step5
Maybe this is a silly question?
I followed Getting Started step1 to step5.
And I have been running BBG booted from eMMC with SD card removed.
In the meantime, I kept update/upgrade on eMMC.
NOW I got BBG BRICKED.
How should I do to recover BBG by putting in SD card without delete all the upgrade/update on eMMC?
NOTE: AS the /boot/uEnv.txt file already change(STEP5 of Getting Started) to flash the eMMC.
use Ext2Fsd to edit uEnv.txt on pc.
You can boot from sd card and then modify /boot/uEnv.txt to enable emmc flasher. When the flashing is complete, all 4 USRx LEDs will be off. The latest Debian flasher images automatically power down the board upon completion. This can take up to 10 minutes. Power-down your board, remove the SD card and apply power again to be complete. thanks.
</s>##enable BBB: eMMC Flasher: cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh<e>
Thank for suggestion!
What if I would like to get the eMMC back to bootable but not reflash it!
I really want to figure out what happened !!
Maybe due to virtual machine or using up all the eMMC space or …
Charles
Hi Charles
You can extract the files out and them check the logs to find the root cause. here is the process how to extract emmc contents. thanks.
<LINK_TEXT text=“https://elinux.org/BeagleBone_Black_Ext … C_contents”>https://elinux.org/BeagleBone_Black_Extracting_eMMC_contents</LINK_TEXT>
Hello my BBGW has been flashed with debian 10, but wifi will not start up
