dso nano <-> transparent double sided tape <-> back panel.
You might want to try removing part of the double sided tape as to avoid sticking it to the lithium polymer battery (the case may rattle but it will greatly reduce the chance of any damage to the battery if you want to remove the back panel. (you may want a small amount of the of the tape on the battery to prevent it from moving)
I recommend using sticky tape to stick down the battery connector (BEFORE putting the back panel on) so that it won’t rattle.
If you want to remove the back panel / get it in the correct spot do so CAREFULLY. Failure to do so carefully may result in you breaking your DSO nano and / or damaging the battery.
In my opinion instructions for this really should be included in the box with the DSO nano.
