There are plenty standard grove cables but for a project I have I want to place the two modules I use as close as possible together. I can’t find any simple solution to connect them directly.
/Andreas
Not quite. I want the opposite of the first connector you posted. Yours is female-female and I want a male-male so I can skip the cable between two modules. The modules have both a female connector that would be ideal to connect to another modules female connector with a little piece in-between.
Yea after I hit send , I relized what you meant. Never have seen one but a good idea non the less
GL
PJ ![]()
basicly it would be the same as what you linked… but opposite
I want to build one with an at-tiny on it so it can have programmable IIC addresses
