rich, try giving it 3v and pressing the sleep button.
mine seems to work except the battery circuit, and it’s a little iritating that it dosn’t come with a programer. they suggested buying a “uart” programer, but a level converter and one of my antiques works fine, inconvenient tho. a pin header on this thing is bad.
temp is probly 350f+. i centered some of the parts on mine and tined some of the pads the copper was already turning dark. just hope the bare link connections dont grow some green bits.
Thanks for trying out the samples, since they are very much in the experimental stage, we are prepared to hear some negative feedbacks. Please try soldering from 300C, they are fragile…
Assembling the 10 pcs sample was very difficult, by hand. I assure you a ready product won’t be so. Please advise if any other major concerns in design of shape, arrangement or functions…
Ps, this should be called Seeeduino Film or “Arduino compatible Seeeduino Film” It’s all about trademark. Thanks!
Ok. thanks. I’ll make sure my friends post here with their feed back.
So the one unit that does not look right, do you want the photos?
Did you test it? So I can be sure that I am just noticing the effect of hand assembling it?
I’ll get that other one in someone elses hand.
