I would like to use the GROVE system base board with an Ethernet Arduino (with ethernet integrated with the arduino board). I understand that the Arduino Ethernet reserves a few pins for internal use… can someone confirm / refute that the GROVE base board works with the Arduino Ethernet?
Mouse
Hi,did you see a ICSP port on your Arduino(6pins port),but our base shield has no this port, and your ethernet need to plug into this port,so problem will occur when you are using our base shield with ethernet…wow,i’m sorry , too wordy …
in a word,you can use base shield , but solder a port on base shield firstly.
