Approving DRC errors okay?
In Eagle I have traces from two different net classes that I want to connect. I’ve tried simply connecting the traces, and I’ve tried using a solder jumper part. In both cases, the project fails the DRC check because the components are too close to one another. Of course, this is okay with me. They’re supposed to be close (overlapping!). Can I just approve this DRC error, create the gerber files, and send them off?
Thanks,
Jeremy
yes, you can ingore it.
i suggest you can set the clearance of same signals as 0mil in DRC rule, the errors will be disappeared.
have a nice day!
dingding
indeed, you can ingore it.
I recommend you can set the leeway of same flags as 0mil in DRC rule, the blunders will be vanished.
have a pleasant day!
dingding
