I have tried to use the 20W USB C Apple charger but Odyssey does not power up. Any ideas if it is meant to work?
Thanks!
Thanks!
Did you power first using the included power supply?
the barrel jack one
12/2A
this is the most basic way to power it
Yes I did. I wonder if it can work with a 20W USB C charger.
@Bruce.Qin do you know if the USB C apple charge is supposed to work?
Anyone else has any luck with a USB C power source?
You need to confirm the supply can be provide 15V output voltage.
@Bruce.Qin thanks a lot. The Apple charger is 14.5 V so it does not work.
Try a PD supply chich can privide 65W.
