Another pb with Multichannel Gas Sensor
I have an annoying problem with the I2C communication with the Gas Sensor. Sometimes, when the CPU reset (ESP32), I am unable to recover the communication with the sensor. the getVersion() is giving me 1 instead of 2 and all the readings are faulty (-1 in general).
The only solution found is to power off the device by unplugging the red cable.
Any way to reset the device via I2C ?
I went through the datasheet. <LINK_TEXT text=“https://raw.githubusercontent.com/Seeed … asheet.pdf”>https://raw.githubusercontent.com/SeeedDocument/Grove-Multichannel_Gas_Sensor/master/res/MiCS-6814_Datasheet.pdf</LINK_TEXT> there is no info about the reset the module. thanks.
Bill
