Hi all,
while following the step by step instructions I got following error. Can you please provide any help? Thanks a lot in advance.
Stefano
(env) pi@raspberrypi:~/avs $ alexa-auth
File “/home/pi/env/bin/alexa-auth”, line 11, in
load_entry_point(‘avs==0.5.4’, ‘console_scripts’, ‘alexa-auth’)()
File “/home/pi/env/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 561, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File “/home/pi/env/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 2631, in load_entry_point
return ep.load()
File “/home/pi/env/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 2291, in load
return self.resolve()
File “/home/pi/env/local/lib/python2.7/site-packages/pkg_resources/init.py”, line 2297, in resolve
module = import(self.module_name, fromlist=[‘name’], level=0)
File “/home/pi/env/local/lib/python2.7/site-packages/avs-0.5.4-py2.7.egg/avs/auth.py”, line 9, in
import tornado.httpserver
File “/home/pi/env/local/lib/python2.7/site-packages/tornado-6.0.2-py2.7-linux-armv7l.egg/tornado/httpserver.py”, line 144
def init(self, *args: Any, **kwargs: Any) -> None:
SyntaxError: invalid syntax
You can try the image, we burned with the driver and avs. you can directly use the 2018-08-06-raspbian-for-respeaker.zip image, run
</s> alexa-auth<e>
<LINK_TEXT text=“https://v2.fangcloud.com/share/7395fd13 … 8000207913”>https://v2.fangcloud.com/share/7395fd138a1cab496fd4792fe5?folder_id=188000207913</LINK_TEXT>
