About Grove-Multichannel Gas Sensor
I downloaded the code from this page.
However, some problems occurred like this.
Therefore, I can’t get usual sensor’s values.
I’m looking forward to your reply.
Hi @tatsuro, if you using the code from the WiKi page your serial monitor baud rate should be 115200 unless you changed it!
so try to change the baud rate from the serial monitor window from 9600 to 115200 .
Hi @salman , thank you for your reply.
When I changed baud rate, the sensor came to run properly.
Thank you so much !!
Happy to know that :star_struck: :love_you_gesture:
