Hello , I buy yesterday the Hercule platform mobile , but the program does not walk . Someome a would a new program which would walk with a remote control ?
seeedstudio.com/wiki/Hercules_Du … pand_Usage
sorry on my english , i’am french
hi, I am the designer of hercule
. I need more details about your problem, would you please talk more about what happens ?
Hello!
I bought Hercules Mobile Platform. I want to know:
Hello the designer of hercule , this is fantastic chassie and very god job
, I do not understand how it works , let me explain by drawing
for the 1 this code is ?
[code]// demo of rfbee send and recv
// loovee 2013
#include <Arduino.h>
#include <EEPROM.h>
#include <RFBeeSendRev.h>
#include <RFBeeCore.h>
unsigned char dtaUart[100]; // serial data buf
unsigned char dtaUartLen = 0; // serial data length
** Function name: setup
** Descriptions: setup
void setup(){
pinMode(10, OUTPUT);
RFBEE.init();
Serial.begin(38400);
Serial.println("ok");
unsigned char rxData1[200]; // data len
unsigned char len1; // len
unsigned char srcAddress1;
unsigned char destAddress1;
char rssi1;
unsigned char lqi1;
int result1;
unsigned char cntGetDta = 5;
** Function name: loop
** Descriptions: loop
if(RFBEE.isDta()) // rfbee get data
result1 = receiveData(rxData1, &len1, &srcAddress1, &destAddress1, (unsigned char *)&rssi1 , &lqi1);
for(int i = 0; i< len1; i++)
Serial.print(rxData1[i]);
if(dtaUartLen) // serial get data
RFBEE.sendDta(dtaUartLen, dtaUart);
dtaUartLen = 0;
void serialEvent()
while (Serial.available())
dtaUart[dtaUartLen++] = (unsigned char)Serial.read();
END FILE
*********************************************************************************************************/[/code]
for the 2 this code is ?
#include <EEPROM.h>
#include <Sleep_n0m1.h>
#include <Power.h>
#include <TimerOne.h>
#define FRAMESTART1 0x53 // data frame start1
#define FRAMESTART2 0x01 // data frame start2
#define FRAMEEND1 0x2f // data frame end1
#define FRAMEEND2 0x45 // data frame end2
#define __DebugRf 0
#define HTCHECK 1
#if __DebugRf
#define __print(X) Serial.print(X)
#define __println(X) Serial.println(X)
#else
#define __print(X)
#endif
#define SPICSHIGH() digitalWrite(10, HIGH)
#define SPICSLOW() digitalWrite(10, LOW)
bool stringComplete = false; // if get data
Sleep sleep;
** Function name: pwrDown
** Descriptions: power down mode, for tSleep ms
void pwrDown(unsigned long tSleep)
unsigned char regTmp;
CCx.Read(0x18, ®Tmp);
CCx.Write(0x18, regTmp|0x01);
CCx.Strobe(CCx_SIDLE); // IDLE
CCx.Strobe(CCx_SFRX); // Flush RX buffer
CCx.Strobe(CCx_SPWD); // Standby
SPICSHIGH();
power_adc_disable();
power_twi_disable();
sleep.pwrDownMode(); //set sleep mode
sleep.sleepDelay(tSleep); //sleep for: sleepTime
** Function name: wakeUp
** Descriptions: wake up
void wakeUp()
power_adc_enable();
power_twi_enable();
SPICSLOW();
RFBEE.init();
** Function name: checkGoodDta
** Descriptions: if uart get good data
unsigned char checkGoodDta(unsigned char *dta)
#if HTCHECK
__println("BEGIN TO CHECK GOOD DATA!!");
for(int i = 0; i < dtaUartLen; i++)
__print(dta[i]);
__print("\t");
__println();
int ioffset = 0;
for(ioffset = 0; ioffset < dtaUartLen; ioffset++)
if(dta[ioffset] == FRAMESTART1 && dta[ioffset+1] == FRAMESTART2)
break;
if(dtaUartLen - ioffset < 6)
__println("get bad data");
return 0;
dtaUartLen -= ioffset;
//dta = &dta[ioffset];
for(int i = 0; ;i++)
dta[i] = dta[i+ioffset];
__print(dta[i]);
__print("\t");
if(dta[i-1] == FRAMEEND1 && dta[i] == FRAMEEND2)
break;
__println();
__println("get good data");
return dtaUartLen;
#else
return 1;
#endif
unsigned char isSleep()
if(dtaUart[2] == 0x55 && dtaUart[3] == 0x55 && dtaUart[4] == 0x55)
__print("ATSLEEP: ");
__println(900);
#if __DebugRf
delay(20);
#endif
pwrDown(900);
wakeUp();
__println(“awake”);
return 1;
return 0;
void setup(){
RFBEE.init();
char rssi1;
unsigned char lqi1;
int result1;
if(RFBEE.isDta())
Serial.write(rxData1[i]);
#if HTCHECK
if(stringComplete)
if(checkGoodDta(dtaUart))
if(isSleep() == 0)
dtaUartLen = 0;
stringComplete = 0;
#else
if(dtaUartLen)
if(isSleep() == 0)
dtaUartLen = 0;
#endif
void serialEvent()
#if HTCHECK
if(dtaUart[dtaUartLen-1] == FRAMEEND2 && dtaUart[dtaUartLen-2] == FRAMEEND1)
stringComplete = 1;
if(dtaUartLen > 80)
dtaUartLen = 0;
stringComplete = 0;
#else
#endif
END FILE
and the 3 this code is ?
[code]/*
remote_lvc.ino
2013 Copyright (c) Seeed Technology Inc. All right reserved.
Author:Loovee
2013-3-18
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-
1301 USA
#include “moto_4wd.h”
#include <pwm_lvc.h>
#include <Wire.h>
bool flagGetI2C = 0;
unsigned char i2cDta[20];
unsigned char dtalen = 0;
unsigned char dirLeft = 0;
unsigned char dirRight = 0;
unsigned char speedLeft = 0;
unsigned char speedRight = 0;
** Function name: getAnalog
** Descriptions: read analog value
MOTOR.init();
Serial.println(“ok”);
Wire.begin(4); // join i2c bus with address #4
Wire.onReceive(receiveEvent); // register event
if(flagGetI2C)
flagGetI2C = 0;
dtalen = 0;
speedLeft = i2cDta[2];
speedRight = i2cDta[3];
dirLeft = speedLeft >= 0x80 ? DIRR : DIRF;
dirRight = speedRight>= 0x80 ? DIRR : DIRF;
dirRight = 1-dirRight;
speedLeft = speedLeft & 0x7f;
speedRight = speedRight & 0x7f;
MOTOR.setSpeedDir1(speedLeft, dirLeft);
MOTOR.setSpeedDir2(speedRight, dirRight);
Serial.print("speed_left = ");Serial.println(i2cDta[2]);
Serial.print("speed_right = ");Serial.println(i2cDta[3]);
delay(1);
void receiveEvent(int howMany)
while(0 < Wire.available()) // loop through all but the last
flagGetI2C = 1;
unsigned int c = Wire.read(); // receive byte as a character
Serial.print(c, DEC); // print the character
Serial.print(“\t”);
i2cDta[dtalen++] = c;
[/code]
my objective to understand your code and also run as chassie radio ![]()
thank you creator ![]()
