树莓派4 respeaker 不可用
树莓派4 内核版本
Linux raspberrypi 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l GNU/Linux
respeaker产品
4-Mic Linear Array Kit for Raspberry Pi
输入arecord -L命令
null
Discard all samples (playback) or generate zero samples (capture)
jack
JACK Audio Connection Kit
pulse
PulseAudio Sound Server
default
ac108
dmixer
ac101
usbstream:CARD=b1
bcm2835 HDMI 1
USB Stream Output
usbstream:CARD=Headphones
bcm2835 Headphones
USB Stream Output
输入aplay -l 命令
**** List of PLAYBACK Hardware Devices ****
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 4/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
seeed-voicecard 日志
  • dtparam i2c_arm=on
  • modprobe i2c-dev
  • dtparam spi=on
  • _VER_RUN=
  • CONFIG=/boot/config.txt
    ++ i2cdetect -y 1 0x1a 0x1a
    ++ awk ‘{print $2}’
    ++ egrep ‘(1a|UU)’
  • is_1a=1a
    ++ i2cdetect -y 1 0x35 0x35
    ++ awk ‘{print $2}’
    ++ egrep ‘(35|UU)’
  • is_35=35
    ++ i2cdetect -y 1 0x3b 0x3b
    ++ egrep ‘(3b|UU)’
    ++ awk ‘{print $2}’
  • is_3b=3b
  • RPI_HATS=‘seeed-2mic-voicecard seeed-4mic-voicecard seeed-8mic-voicecard’
  • overlay=
  • ‘[’ x1a ‘!=’ x ‘]’
  • ‘[’ x35 == x ‘]’
  • ‘[’ x3b ‘!=’ x ‘]’
  • ‘[’ x35 == x ‘]’
  • ‘[’ x35 ‘!=’ x ‘]’
  • echo ‘install 6mic’
    install 6mic
  • overlay=seeed-8mic-voicecard
  • asound_conf=/etc/voicecard/asound_6mic.conf
  • asound_state=/etc/voicecard/ac108_6mic.state
  • ‘[’ seeed-8mic-voicecard ‘]’
  • echo Install seeed-8mic-voicecard …
  • rm /etc/asound.conf
  • rm /var/lib/alsa/asound.state
  • dtoverlay seeed-8mic-voicecard
  • echo ‘create seeed-8mic-voicecard asound configure file’
  • ln -s /etc/voicecard/asound_6mic.conf /etc/asound.conf
  • echo ‘create seeed-8mic-voicecard asound status file’
  • ln -s /etc/voicecard/ac108_6mic.state /var/lib/alsa/asound.state
  • alsactl restore
    No state is present for card b1
    Found hardware: “bcm2835_hdmi” “Broadcom Mixer” “” “” “”
    Hardware is initialized using a generic method
    No state is present for card Headphones
    Found hardware: “bcm2835_headpho” “Broadcom Mixer” “” “” “”
  • amixer cset numid=3 1
    amixer: Cannot find the given element from control default
