USB Analyzer [DSO Quad Application Software Design Entry]
jpa
Elementary-2
Elementary-2
Which products/projects are your favorite?: DSO Quad
Post by jpa » Sun Jan 13, 2013 6:51 am
This is an USB Protocol Analyzer for the DSO Quad Application design competition:
See here for more details:
http://essentialscrap.com/dsoquad/usb.html
Downloads here (it needs QuadPawn 0.06 or newer):
http://koti.kapsi.fi/~jpa/dsoquad/#USB%20Analyzer
gabonator1
Kindergarten
Kindergarten
Which products/projects are your favorite?: dso quad
Re: USB Analyzer [DSO Quad Application Software Design Entry
Post by gabonator1 » Sun Jan 13, 2013 10:55 pm
Amazing work! I Cant wait until I use it as hardware keyboard sniffer :) And is it really necessary to measure both D+/D- wires? The are forming a differential pair and most of the time they hold the same logic level on both lines.
jpa
Elementary-2
Elementary-2
Post by jpa » Sun Jan 13, 2013 11:14 pm
It would be quite easy to hack it to only show the contents of DATA packets.. that would make an excellent keyboard sniffer :)
End of packet is signalled in USB by pulling both D+ and D- to ground. I'm not sure if it is possible to detect it otherwise. Other than that, a single signal would be enough.
c.wilt
Post by c.wilt » Mon Jan 14, 2013 11:20 pm
Very nice addition. Thank you.
alvadep
Which products/projects are your favorite?: DSOQuadV2.6
Post by alvadep » Wed Feb 13, 2013 4:53 am
I established the PAWN_006 version. USB Analyzer works normally, but with this version Frequency Response doesn't work (FREQ001, doesn't work at other modes absolutely). Frequency Response perfectly works with PAWN_002 (FREQ000), but USB Analyzer and many other things doesn't work.
jpa
Elementary-2
Elementary-2
Post by jpa » Wed Feb 13, 2013 11:37 pm
alvadep wrote:I established the PAWN_006 version. USB Analyzer works normally, but with this version Frequency Response doesn't work.
Ok, I can see that there is a problem. For me it just stops midway through the measurement. I'll debug that problem.
Can you tell what are the exact settings you use for testing? The results you get look a lot like the input probe (channel A) was just disconnected.
alvadep
Post by alvadep » Wed Feb 13, 2013 11:56 pm
minfreq = 2
maxfreq = 3
waveform = 0
clear = 1
steps = 3
reference = 0
PAWN_002 with these parameters works. PAWN_006 with these parameters hangs (even scanning doesn't begin). On PAWN_006 it was possible though any result to receive for save only at maxfreq - 20k. Change only PAWN. All the rest without changes.
jpa
Elementary-2
Elementary-2
Post by jpa » Thu Feb 14, 2013 2:57 am
This bug should be now fixed in PAWN_007. Available from
http://koti.kapsi.fi/jpa/dsoquad/#QuadPawn
The bug was caused by the new GCC version (4.7.3 vs. old 4.6.1) optimizing things differently. This caused a few bugs in the time-critical wavein loop to come visible.
There is also a new version of freqresp. But it is only a small speedup, not related to this bug:
https://github.com/PetteriAimonen/QuadP ... eqresp.amx
alvadep
Post by alvadep » Thu Feb 14, 2013 5:28 am
jpa, you do such lot of work, huge to you thanks.
Freqresp earned with the new PAWN version. Wasn't started only scanning with minfreq - 10Hz, maxfreq - 20MHz . But with the new freqresp version everything fell into place, everything earned of full.
And here new LOGICAPP versions don't work for me. I have works only the version of March, 2012, in size 66,3 kb. I have very old HW (v 2.6).
Excuse me for my English and off topic.
