Hi there~
Please follow below instructions.
DOA without Keywords
Step 1. Setup the dependency
</s>sudo apt-get install portaudio19-dev
sudo pip install pyaudio
sudo pip install webrtcvad
sudo apt-get install python-numpy
sudo pip install pyusb
<e>
Step 2. Run the vad_doa.py
</s>cd ~
git clone https://github.com/respeaker/mic_array.git
cd mic_array
nano vad_doa.py
#change to below code, then run python vad_doa.py <e>
Here is the vad_doa.py code, which disable the doa.
[code]
import sys
import webrtcvad
import numpy as np
from mic_array import MicArray
#from pixel_ring import pixel_ring
RATE = 16000
CHANNELS = 8
VAD_FRAMES = 10 # ms
#DOA_FRAMES = 200 # ms
def main():
vad = webrtcvad.Vad(3)
speech_count = 0
chunks = []
#doa_chunks = int(DOA_FRAMES / VAD_FRAMES)
try:
with MicArray(RATE, CHANNELS, RATE * VAD_FRAMES / 1000) as mic:
for chunk in mic.read_chunks():
# Use single channel audio to detect voice activity
if vad.is_speech(chunk[0:].tobytes(), RATE):
speech_count += 1
sys.stdout.write('1')
else:
sys.stdout.write('0')
sys.stdout.flush()
chunks.append(chunk)
#if len(chunks) == doa_chunks:
#if speech_count > (doa_chunks / 2):
#frames = np.concatenate(chunks)
#direction = mic.get_direction(frames)
#pixel_ring.set_direction(direction)
#print('\n{}'.format(int(direction)))
#speech_count = 0
#chunks = []
except KeyboardInterrupt:
pass
pixel_ring.off()
if name == ‘main’:
main()
[/code]
Run the vad python code.
</s>pi@raspberrypi:~/mic_array $ python vad_doa.py
Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
ALSA lib pcm_dmix.c:990:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
(0, 'bcm2835 ALSA: IEC958/HDMI (hw:0,1)', 0L, 2L)
(1, 'seeed-8mic-voicecard: - (hw:1,0)', 8L, 8L)
Use seeed-8mic-voicecard: - (hw:1,0)
111111100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000011111111111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001111111000000000000000000000000000000000000000000011111111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001111111100000000000000000000000000011111111111111111101111111111000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000011111111111111110000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000pi@raspberrypi:~/mic_array $<e>
