A few questions about the LicheePi Nano
Hello I have the LicheePi Nano on its way being sent to me and I have a few questions. It’s this particular model: <LINK_TEXT text=“https://www.seeedstudio.com/Sipeed-Lich … -2893.html”>https://www.seeedstudio.com/Sipeed-Lichee-Nano-Linux-Development-Board-16M-Flash-WiFi-Version-p-2893.html</LINK_TEXT>
  1. Is it possible to use the wifi module with a microSD card at the same time? It looks like they both go into the same slot.
  2. Would this be compatible with a small SPI interface e-paper display?
    <LINK_TEXT text=“www.aliexpress.com/item/32810660608.htm … hweb201603”>www.aliexpress.com/item/32810660608.html?spm=a2g0o.productlist.0.0.557b3b52uKIUsD&algo_pvid=5872dbc7-18ea-4f73-86ac-bd4f9ec59cf6&algo_expid=5872dbc7-18ea-4f73-86ac-bd4f9ec59cf6-0&btsid=0ab50f0815816345799375848ee955&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603</LINK_TEXT>_
  3. Can I use a 3.7v lipo battery to power it? It says you can use 3.3v to 5v via pin to power it and I can use a diode to drop the battery voltage down to 3.3v.
    <LINK_TEXT text=“https://www.aliexpress.com/item/4000136 … hweb201603”>https://www.aliexpress.com/item/4000136709029.html?spm=a2g0o.productlist.0.0.6a72a05bn8Cnlg&algo_pvid=f2bcc11c-eb02-4e40-85e7-f179a6b03ef3&algo_expid=f2bcc11c-eb02-4e40-85e7-f179a6b03ef3-10&btsid=0ab50f0815817112182122412ee92c&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603</LINK_TEXT>_
  1. Since they both use SPI and the Lichee Nano two SPI port , you can do that .
  2. You might need to write the lib if it’s not availble.
  3. Yess, but you also need to use you own lipo battery charger too.
Hi salman. could help me. Where can I download the images that the documentation says is here. https://pan.baidu.com/s/1smzuGS9 I have tried but I could not. Thanks you very much in advance.
Alleiny.
You mean you can’t download it? @alleiny_Machado
