DSO203 GCC APP - Community Edition (2.51+SmTech1.8+Fixes)
Jerson
Kindergarten
Kindergarten
Which products/projects are your favorite?: dso Nano, dso nano quad
Contact:
Re: DSO Quad GCC port (2.51+SmTech1.8+Fixes)
Post by Jerson » Mon Mar 05, 2012 2:25 pm
Hi Pedro
I took the files from the Github latest release 1.12
Always comes back with ERR or NOT
Regards
pmos69
Elementary-1
Elementary-1
Which products/projects are your favorite?: dso203
Post by pmos69 » Mon Mar 05, 2012 2:28 pm
Jerson wrote:Hi Pedro
Regards
Try extracting from the zip (on the first post).
Github has the nasty habit of messing up binary files...
Jerson
Kindergarten
Kindergarten
Contact:
Post by Jerson » Mon Mar 05, 2012 2:34 pm
Hi Pedro
Thank you very much. That did the trick. It works now. Surprising since I downloaded even the ZIP from Github
Thanks again
Regards
Jerson
pmos69
Elementary-1
Elementary-1
Post by pmos69 » Mon Mar 05, 2012 2:36 pm
Thanks again
Regards
Jerson
Yes, I think it's git that does some sort of conversion right when I upload things.
Would fix it, but my git knowledge is very limited :/
Jerson
Kindergarten
Kindergarten
Contact:
Post by Jerson » Mon Mar 05, 2012 2:47 pm
First impressions. FFT seems to lose the ending frequency when going >= 5uS. I love the 2nd button press choosing the trigger levels. Very handy
Regards
Jerson
pmos69
Elementary-1
Elementary-1
Post by pmos69 » Mon Mar 05, 2012 3:16 pm
Jerson wrote:First impressions. FFT seems to lose the ending frequency when going >= 5uS. I love the 2nd button press choosing the trigger levels. Very handy
Regards
Jerson
Yes, the FFT is a bit "crude", but I just wanted to get a working version running. The thing with the ending frequency seems like a question of datatype or datatype conversion, but I didn't really look into it.
I've also used the FFT with 1024 points instead of 256 and it runs without issues and is much more precise, but displaying that involves a bit more work, scaling the output to the display window (and I didn't do that.)
The trigger level presets is all Marco's work :)
PS: oh, and I think I fixed the github binary files corruption thing...
pmos69
Elementary-1
Elementary-1
Post by pmos69 » Mon Mar 05, 2012 6:29 pm
Code: Select all
v1.13
- Corrections in the FFT calculations
		(was making a mess, as usual)
glt
Post by glt » Tue Mar 06, 2012 2:34 am
Let me take this opportunity and give a big thanks to Pedro, Marco and others that have incrementally contributed to improving the s/w. I think this was the original intend of this product, and gracious individuals have taken upon themselves the task to deliver the s/w. BRAVO!
paf
Post by paf » Tue Mar 06, 2012 5:22 am
Yes, Marco and then Pedro did a great job, thank you very much. And the work of Pedro allows each of us to compile the firmware using a free compiler.
The integration of FFT is very nice but I don't understand what it measures exactly. Look at the following example (230V mains with 10x probe):
Two things irritate me:
  • why so many harmonics? The mains should be a very good sine, I don't expect anything significant above 50Hz. Is this noise because of the limited resolution of the ADC? Or a "feature" of the FFT? Of because of the vertical logarithmic scale?
  • the rays in the spectrum are not really rays, they are rather blurred - is that a "feature" of the FFT too (e.g. because of the width of the bandpass filter?)
Patrick
pmos69
Elementary-1
Elementary-1
Post by pmos69 » Tue Mar 06, 2012 7:11 am
I would say the calculations are incorrect...
...or not.
I wouldn't say an 8bit capture of a sine with about 30 samples per cycle like you show is a very good representation of a sine wave.
It's a very poor one actually, and it would be strange to not get a lot of harmonics.
If you increase the time resolution (samples per cycle) you'll start getting better results.
Image Image Image
...but please remember - this is a 256 samples FFT.
It's usefulness is limited.
Had some problems reverting back to the 1024 points FFT I had first implemented, and will probably not be trying to get it running any time soon.
If someone want's to have a go at it... (all the FFT related code in the source is delimited with "// FFT" comments, and is actually very few lines of code)
