4 Mic Linear Array not recognized
Applications/questions using Raspberry Pi with Seeed products, please post it here.
Moderators: lily.li, salmanfarisvp, violet
david_palacios
Re: 4 Mic Linear Array not recognized
Post by david_palacios » Fri Jun 21, 2019 10:29 am
I've followed the instruction, but nothing seems to work. Should I use the raspbian image you posted on this thread? When would the wiki page be updated? I've been struggling with this issue for weeks know.
Best
bill.yu
Junior-7
Junior-7
Post by bill.yu » Fri Jun 21, 2019 3:03 pm
Hi there~,
I follow wiki page and test it well. Can you use the audacity to record the audio files,please? THANKS.
Code: Select all
pi@raspberrypi:~ $ pulseaudio --start
N: [pulseaudio] main.c: User-configured server at {74222c7487734792b86d4eb5302d9ef4}unix:/run/user/1000/pulse/native, which appears to be local. Probing deeper.
pi@raspberrypi:~ $ pactl info
Server String: unix:/run/user/1000/pulse/native
Library Protocol Version: 32
Server Protocol Version: 32
Is Local: yes
Client Index: 7
Tile Size: 65496
User Name: pi
Host Name: raspberrypi
Server Name: pulseaudio
Server Version: 10.0
Default Sample Specification: s32le 8ch 96000Hz
Default Channel Map: front-left,front-left-of-center,front-center,front-right,front-right-of-center,rear-center,aux0,aux1
Default Sink: alsa_output.platform-soc_sound.seeed-2ch
Default Source: alsa_input.platform-soc_sound.seeed-8ch
Cookie: c7b7:a27d
pi@raspberrypi:~ $ source ~/env/bin/activate
(env) pi@raspberrypi:~ $ cd ~/voice-engine/examples
(env) pi@raspberrypi:~/voice-engine/examples $ python kws_alexa_for_4mic_liner_pihat.py
['arecord', '-t', 'raw', '-f', 'S16_LE', '-c', '8', '-r', '16000', '-D', 'default', '-q']
david_palacios
Post by david_palacios » Mon Jun 24, 2019 10:59 am
Ok, so I tried this a few times and I've noticed that sometimes audacity does not recognize the input device, I need to reinstall the sound card a few times for it to appear. It finally recorded and played in audacity, alexa worked, but after the first use it stops working saying that ssl handshake failed. I reinstalled everything and the input device is recognized by audacity, but I can't get sound from the speaker jack, but rather from the raspberry pi 3.5 mm jack. When I use aplay and arecord I can't use it again, since I get a 'Device or resource busy' error. Do I have to keep reinstalling the driver until it works? And once it does, would I have to do everything all over again?
bill.yu
Junior-7
Junior-7
Post by bill.yu » Tue Jun 25, 2019 10:29 am
Hi there~
For the work around, you can download the 2018.08.06 raspbian for respeaker image. it includes the drivers and avs as well. We are trying to simulate your issue. thanks.
https://v2.fangcloud.com/share/7395fd13 ... 13&lang=en
david_palacios
Post by david_palacios » Tue Jun 25, 2019 11:19 am
I'll try that. Thanks
david_palacios
Post by david_palacios » Fri Jun 28, 2019 11:50 am
I tried the Raspbian image you suggested and it’s the same story. I’ll try to describe my problem, because I get the exact same behavior when I follow the wiki steps. I’ve tried to install the drivers using the 4 mic linear array as well as the circular 6 mic array and no luck so far.
In the following message I'll copy the entire terminal activity when following the wiki steps. Maybe that’ll give you a better idea of what’s going on.
Best regards
David
david_palacios
Post by david_palacios » Fri Jun 28, 2019 12:22 pm
pi@raspberrypi:~ $ sudo apt-get update
Des:1 http://linux.teamviewer.com/deb stable InRelease [9.388 B]
Obj:2 http://archive.raspberrypi.org/debian stretch InRelease
Obj:3 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Des:4 http://linux.teamviewer.com/deb stable/main armhf Packages [2.577 B]
Descargados 12,0 kB en 1s (6.009 B/s)
Leyendo lista de paquetes... Hecho
pi@raspberrypi:~ $ sudo apt-get upgrade
Creando árbol de dependencias
Leyendo la información de estado... Hecho
Calculando la actualización... Hecho
El paquete indicado a continuación se instaló de forma automática y ya no es necesario.
realpath
Utilice «sudo apt autoremove» para eliminarlo.
0 actualizados, 0 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
pi@raspberrypi:~ $ sudo apt autoremove
Los siguientes paquetes se ELIMINARÁN:
realpath
0 actualizados, 0 nuevos se instalarán, 1 para eliminar y 0 no actualizados.
Se liberarán 461 kB después de esta operación.
¿Desea continuar? [S/n] s
(Leyendo la base de datos ... 143519 ficheros o directorios instalados actualmente.)
Desinstalando realpath (8.26-3) ...
pi@raspberrypi:~ $ cd seeed-voicecard
bash: cd: seeed-voicecard: No existe el fichero o el directorio
pi@raspberrypi:~ $ git clone https://github.com/respeaker/seeed-voicecard.git
Cloning into 'seeed-voicecard'...
remote: Enumerating objects: 46, done.
remote: Counting objects: 100% (46/46), done.
remote: Compressing objects: 100% (34/34), done.
remote: Total 688 (delta 19), reused 31 (delta 12), pack-reused 642
Receiving objects: 100% (688/688), 1.33 MiB | 1.04 MiB/s, done.
Resolving deltas: 100% (418/418), done.
pi@raspberrypi:~/seeed-voicecard $ sudo ./install.sh
Obj:1 http://linux.teamviewer.com/deb stable InRelease
Todos los paquetes están actualizados.
raspberrypi-kernel ya está en su versión más reciente (1.20190517-1).
raspberrypi-kernel-headers ya está en su versión más reciente (1.20190517-1).
dkms ya está en su versión más reciente (2.3-2).
git ya está en su versión más reciente (1:2.11.0-3+deb9u4).
i2c-tools ya está en su versión más reciente (3.1.2-3).
libasound2-plugins ya está en su versión más reciente (1.1.1-1).
Deleting module version: 0.3
completely from the DKMS tree.
Done.
Creating symlink /var/lib/dkms/seeed-voicecard/0.3/source ->
/usr/src/seeed-voicecard-0.3
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....
make -j4 KERNELRELEASE=4.19.42+ -C /lib/modules/4.19.42+/build M=/var/lib/dkms/seeed-voicecard/0.3/build......
DKMS: build completed.
snd-soc-wm8960:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/4.19.42+/kernel/sound/soc/codecs/
snd-soc-ac108.ko:
- Original module
- Installation
snd-soc-seeed-voicecard.ko:
- Original module
- Installation
- Installing to /lib/modules/4.19.42+/kernel/sound/soc/bcm/
depmod....
DKMS: install completed.
Building module:
make -j4 KERNELRELEASE=4.19.42-v7+ -C /lib/modules/4.19.42-v7+/build M=/var/lib/dkms/seeed-voicecard/0.3/build......
snd-soc-wm8960:
- Original module
- Installation
- Installing to /lib/modules/4.19.42-v7+/kernel/sound/soc/codecs/
snd-soc-ac108.ko:
- Original module
- Installation
- Original module
- Installation
- Installing to /lib/modules/4.19.42-v7+/kernel/sound/soc/bcm/
depmod....
mkdir: no se puede crear el directorio «/etc/voicecard»: El fichero ya existe
setup git config
git init
Reinitialized existing Git repository in /etc/voicecard/.git/
git add --all
git commit -m "origin configures"
[master (root-commit) 50dc3e4] origin configures
7 files changed, 1476 insertions(+)
create mode 100644 ac108_6mic.state
create mode 100644 ac108_asound.state
create mode 100644 asound_2mic.conf
create mode 100644 asound_4mic.conf
create mode 100644 asound_6mic.conf
create mode 100644 dkms.conf
create mode 100644 wm8960_asound.state
Please reboot your raspberry pi to apply all settings
Enjoy!
pi@raspberrypi:~/seeed-voicecard $ reboot
These images show what happens after reboot:
https://www.dropbox.com/s/putdc6ylrpmsv ... 5.jpg?dl=0
This is what happens when I try to use alexa:
https://www.dropbox.com/s/oap26vo5e3v2y ... 2.jpg?dl=0
What happens when using audacity:
https://www.dropbox.com/s/akwepjn6kos0c ... 7.jpg?dl=0
https://www.dropbox.com/s/3r0lgxdskusdg ... 0.jpg?dl=0
bill.yu
Junior-7
Junior-7
Post by bill.yu » Fri Jun 28, 2019 4:07 pm
Hi there~
1. If you use above image, you do not need to install the driver. You just need to run the arecord -L. Please also take a picture about your mics FPC cable connection in case the wrong connections as well. You can reboot one more time to check if you can see the sound card.
2. We tested with latest kernel Linux raspberrypi 4.19.42-v7 and it works as well.
Code: Select all
(env1) pi@raspberrypi:~ voice-engine/examples $  uname -a
Linux raspberrypi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
(env1) pi@raspberrypi:~ voice-engine/examples $ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: seeed8micvoicec [seeed-8mic-voicecard], device 0: bcm2835-i2s-ac10x-codec0 ac10x-codec.1-0035-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
(env1) pi@raspberrypi:~ oice-engine/examples $
2. we see some pulse audio issue and update the wiki page for the alexa interaction python scripts. you can check the wiki for the detail info. thanks.
