XIAO Overheating when using usb power and battery power
Hi
@kkirbatski Are you connecting two batteries in parallel and connecting the positive and negative poles to the power pin of xiao’s GPIO and ground pin? If you use the GPIO pin to power it up, voltage input connected to general I/O pins may cause chip damage if it’ higher than 3.3V.
