Thanks for your answer,
i am able to load the blinky example onto the board, so I think my setup is correct. Which LSM example did you use? I am not able to get a response using this example code:
Klick
Changing the protocol stack also did nothing for the example above.
I will try to run an I2C scanner and give an update. But wiring should not be an issue, as the sensor is wired onboard…
