Thank you very much for your kind assistance.
You are correct. The WiFi Camera Server does continue to run after the USB-C is disconnected and the battery still connected. But, the video freezes. The settings menu remains active, however. I can still start and stop the stream, but then, there is no video without the USB-C.
With regard to your suggestion:
while(!Serial); //When the serial port is opened, the program starts to execute.
Are you suggesting that I add a while loop to the sketch?
Thank you again for your assistance.
Best regards,
Larry
