WIO Terminal library missing file
Hi @David_Hancock,
Have you updated all your libraries to the latest version?
This problem seems like you are using the master branch of Seeed_Arduino_mbedtls:
You should use the dev branch instead:
Also, make sure to update the SAMD Core of Wio Terminal by visiting Arduino IDE.
  • Go to Tools > Board > Boards Manager
  • Type Wio Terminal in the search box
  • Select the latest version and install
Beset Regards,
Lakshantha
1.8.1 is installed- and still no joy-
fatal error: esp_system.h: No such file or directory
#include <esp_system.h>
Hi @David_Hancock,
Can I know how you downloaded and installed all the libraries?
Did you download them as .ZIP and installed them from Arduino IDE, or used git clone method?
Also, can I see a screenshot of your Arduino Libraries folder?
Best Regards,
Lakshantha
As per instructions added via.Zip
Hi @David_Hancock,
Could you delete Seeed_Arduino_mbedtls-master folder and download .ZIP from here:
You have installed the master branch of Seeed_Arduino_mbedtls. You need to install the dev branch.
After you install the above library, you will notice the name of the folder in your Arduino Libraries Folder as Seeed_Arduino_mbedtls-dev.
Hope it helps.
Best Regards,
Lakshantha
Thanks That Did It. You have been most helpful.
