Wio Lite MG126 - errors when compiling
Hi there~
Please refer to step 4 of the software session of wiki page. thanks.
http://wiki.seeedstudio.com/Wio-Lite-MG126/#software
  1. Open the platform.txt file in the folder: C:\Users$(USER_NAME)\AppData\Local\Arduino15\packages\Seeeduino\hardware\Seeeduino_Wio_Lite_BLE\1.0.0\platform.txt
  2. Go to line 75 and line 76.
    ##recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" “-L{build.path}” {compiler.c.elf.flags} {compiler.c.elf.extra_flags} “-T{build.variant.path}/{build.ldscript}” “-Wl,-Map,{build.path}/{build.project_name}.map” --specs=nano.specs --specs=nosys.specs {compiler.ldflags} -o “{build.path}/{build.project_name}.elf” {object_files} -Wl,–start-group {compiler.arm.cmsis.ldflags} -lm “{build.path}/{archive_file}” -Wl,–end-group
    recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" “-L{build.path}” {compiler.c.elf.flags} {compiler.c.elf.extra_flags} “-T{build.variant.path}/{build.ldscript}” “-Wl,-Map,{build.path}/{build.project_name}.map” --specs=nano.specs --specs=nosys.specs {compiler.ldflags} -o “{build.path}/{build.project_name}.elf” {object_files} {compiler.libraries.ldflags} -Wl,–start-group {compiler.arm.cmsis.ldflags} -lm “{build.path}/{archive_file}” -Wl,–end-group
  3. If the sample program has a Bluetooth library called, you need to add ## in front of line 75 (ie, comment the line), at the same time, you need to delete ## in front of line 76 (ie, uncomment). Conversely, if the Bluetooth library is not called, but the basic operation of the SAM D21 development board is used, the operation is reversed.
  4. You can find 7 demos in this folder. The button/get_bat_vol demos do not use the bluetooth library, and the rest do.
