WIFiMulti library doesen't work
Hi @turmary, I also did the tests but the routine works correctly only if I enter the wifiMulti.run () command twice. The first does not solve the sequence, the second is successful. Keep in mind that to do this test I entered three AP addresses and the first two are not reachable. For now I have solved this way but I do not understand why it is not successful the first time. if you need me to do test reports, tell me what to do.
Thank you
