Trouble with LoRaWAN Gateway Module WM1302 + WM1302 Pi Hat
I had the same issue. I believe it it something to do with echoing out pins. After so searching around and chatGPT help I found that changing the way the resent pins get set is what fixed it for me (avoid echoing).
This is my reset_lgw.sh code:
(I am using WM1302/SX1302 so no need for the SX1261 reset lines)
  GNU nano 7.2
# Usage examples:
#       ./reset_lgw.sh stop
#       ./reset_lgw.sh start
# GPIO mapping has to be adapted with HW
SX1302_RESET_PIN=17
SX1302_POWER_EN_PIN=18
reset() {
   echo "CoreCell reset through GPIO$SX1302_RESET_PIN..."
     gpioset gpiochip0 $SX1302_RESET_PIN=1
     sleep 0.1
     gpioset gpiochip0 $SX1302_RESET_PIN=0
     sleep 0.1
term() {
   # "unexport" (set back to "input" by reading its value)
   gpioget gpiochip0 $SX1302_RESET_PIN
case "$1" in
    start)
    term # just in case
    reset
    stop)
    reset
    term
    echo "Usage: $0 {start|stop}"
    exit 1
esac
exit 0
