🩺 Technical Reference Manual vs. The Datasheet
And Welcome here…
So I won’t assume you mean a full Dev Kit C6 but a Xiao
YMMV I follow this basic understanding. The DEV-Kit C (C6) is different because of the size…just fyi.
:v:
Xiao ESP32C6 Safe I/O Pin Reference Table
Label GPIO Safe for I/O? Notes
D0 0 :warning: Input only Boot pin – LOW to enter flash mode; don’t use as output
D1 1 :x: No SPI Flash pin – Do not use
D2 2 :x: No SPI Flash
D3 3 :x: No SPI Flash
D4 4 :x: No SPI Flash
D5 5 :white_check_mark: Yes Safe for I/O
D6 6 :white_check_mark: Yes Safe
D7 7 :white_check_mark: Yes Safe
D8 8 :white_check_mark: Yes Safe
D9 9 :white_check_mark: Yes Safe
D10 10 :white_check_mark: Yes Safe
A0 1 :x: No Same as D1 — do not use
A1 0 :warning: Input only Same as D0 — boot pin
A2 2 :x: No Same as D2 — SPI Flash
A3 3 :x: No Same as D3 — SPI Flash
3V3 — Power only 3.3V output
5V — Power only USB input (not from LDO)
GND — Ground Common ground
Use These Xiao ESP32C6 Pins for I/O:
  • D5, D6, D7, D8, D9, D10 → Fully safe for digital I/O, PWM, etc.
  • GPIOs 5–10 are your reliable workhorses.
  • Avoid D0–D4 due to boot functions or flash interference.
Tip for Analog / PWM:
If you’re using analog input/output:
  • ADC works best on D5–D10
  • For PWM, all those safe GPIOs support LEDC PWM channels
for this…for example
pinMode(D5, OUTPUT);
digitalWrite(D5, HIGH); // Safe and solid
for Analog in Basic,
int sensor = analogRead(D9); // Works fine on safe GPIO
Why This Matters
  • Pins D1–D4 interfere with flash memory or USB/JTAG, which can brick or destabilize your board.
  • Using the safe GPIOs (5–10) ensures reliability and avoids subtle bugs.
  • Leveraging GPIOs like 14 and 15 gives you control over antenna switching and onboard LEDs.
