Hi I tested the LED with nodejs successfully. the LED uses the SPI and audio uses the I2S. we have to enable te spi first by following https://www.w3schools.com/nodejs/nodejs_raspberrypi.asp.
- install dependiences
sudo apt-get update
sudo apt-get dist-upgrade
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
node -v
npm install apa102-spi
- please create a led.js file with below code.
var Apa102spi = require(‘apa102-spi’)
// Apa102spi(number of leds, clock divider)
var LedDriver = new Apa102spi(9, 100)
// setLedColor(n, brightness 0-31, red 0-255, green 0-255, blue 0-255) , n=0 led1; n=1, led2; n=2, led3;
LedDriver.setLedColor(0, 1, 255, 0, 0)
// send data to led string
LedDriver.sendLeds()
- run node led.js and see the led turned on.
For the I2S, i do not test it. thanks.
Seeed techsupport team
Bill
