MR60BHA1 - Report, Send and Read in RospberryPI Python
Jostar,
Below is my code and output.
import os
import serial
from time import sleep
import numpy as np
from datetime import datetime
os.system(‘sudo chmod +777 /dev/ttyS0’)
print("", file=open(‘output.txt’, ‘a’))
print(datetime.now().strftime(’%Y-%m-%d-%H-%M-%S’))
def fetch_and_update_radar_data():
ser = serial.Serial ("/dev/ttyS0", 115200)
# read all the data reported at power cycle.
# no command is required from application program
msgRaw = bytearray(bytes(128))
sleep(1)
ndx = 0
while ser.in_waiting:
	readByte = ser.read(1)
	number = int.from_bytes(readByte, byteorder='big')
	msgRaw[ndx] = number
	ndx = ndx+1
msgNew = bytearray(bytes(ndx))
for x in range(ndx):
	msgNew[x] = msgRaw[x]
print("Rp", datetime.now().strftime('%Y-%m-%d %H:%M:%S'), msgNew, file=open('output.txt', 'a'))
print("Rp", datetime.now().strftime('%Y-%m-%d %H:%M:%S'), msgNew)
flag = True
while flag == True:
	sleep(10)
	msgRaw = bytearray(bytes(256))
	msgWrite = [bytes([0x53, 0x59, 0x80, 0x81, 0x00, 0x01, 0x0F, ((0x53 + 0x59 + 0x80 + 0x81 + 0x00 + 0x01 + 0x0f) & 0xFF), 0x54, 0x43]),
				bytes([0x53, 0x59, 0x07, 0x87, 0x00, 0x01, 0x0F, ((0x53 + 0x59 + 0x07 + 0x87 + 0x00 + 0x01 + 0x0f) & 0xFF), 0x54, 0x43]), # out of bound status
				bytes([0x53, 0x59, 0x01, 0x80, 0x00, 0x01, 0x0F, ((0x53 + 0x59 + 0x01 + 0x80 + 0x00 + 0x01 + 0x0F) & 0xFF), 0x54, 0x43]), # Heartbeat Package Inquiry
				bytes([0x53, 0x59, 0x01, 0x02, 0x00, 0x01, 0x0F, ((0x53 + 0x59 + 0x01 + 0x02 + 0x00 + 0x01 + 0x0F) & 0xFF), 0x54, 0x43]), # Module Reset
				bytes([0x53, 0x59, 0x02, 0xA1, 0x00, 0x01, 0x0F, ((0x53 + 0x59 + 0x02 + 0xA1 + 0x00 + 0x01 + 0x0F) & 0xFF), 0x54, 0x43]), # Product Model
	i = 1 # change i values for selection of command
	print("Sending ", msgWrite[i])
	print("W", datetime.now().strftime('%Y-%m-%d %H:%M:%S') , msgWrite[i], file=open('output.txt', 'a'))
	ser.write(msgWrite[i])
	sleep(.1)
	ndx = 0
		ndx = ndx+1
	print("R", datetime.now().strftime('%Y-%m-%d %H:%M:%S'), msgNew, file=open('output.txt', 'a'))
	print("R", datetime.now().strftime('%Y-%m-%d %H:%M:%S'), msgNew)
def main():
#while 1:
main()
Out put file
Rp 2023-08-01 22:31:24 bytearray(b’\x04\xd0\xcc\xc4’)
W 2023-08-01 22:31:34 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:31:34 bytearray(b’’)
W 2023-08-01 22:31:44 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:31:45 bytearray(b’’)
W 2023-08-01 22:31:55 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:31:55 bytearray(b’’)
Rp 2023-08-01 22:32:05 bytearray(b’Y\x80\x03\x00\x01\x044TCSY\x80\x05\x00\x04\x00_\x00Z\xeeTC’)
W 2023-08-01 22:32:15 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:32:15 bytearray(b’’)
W 2023-08-01 22:32:25 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:32:25 bytearray(b’’)
W 2023-08-01 22:32:35 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:32:35 bytearray(b’’)
Rp 2023-08-01 22:37:14 bytearray(b’Y\xf1\x88\xf6’)
W 2023-08-01 22:37:24 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:37:24 bytearray(b’’)
W 2023-08-01 22:37:34 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:37:34 bytearray(b’’)
W 2023-08-01 22:37:44 b’SY\x02\xa1\x00\x01\x0f_TC’
R 2023-08-01 22:37:44 bytearray(b’’)
Rp 2023-08-01 22:38:02 bytearray(b’Y\x80\x02\x00\x01\x021TCSY\x80\x03\x00\x01\x13CTCSY\x80\x04\x00\x02\x00BtTC’)
W 2023-08-01 22:38:12 b’SY\x07\x87\x00\x01\x0fJTC’
R 2023-08-01 22:38:12 bytearray(b’’)
W 2023-08-01 22:38:22 b’SY\x07\x87\x00\x01\x0fJTC’
R 2023-08-01 22:38:22 bytearray(b’’)
W 2023-08-01 22:38:32 b’SY\x07\x87\x00\x01\x0fJTC’
R 2023-08-01 22:38:32 bytearray(b’’)
