I tried to compile in linux and found some problems. The first problem is that I didn’t have instructions on how you expected to compile the code so I did this:
cd Build/arm_linux
make
which is not what I think you did, but anyway that is what I eventually got to work. Unfortunately I had to change quite a bit of stuff including:
mv Source/HwLayer/bios.h Source/HwLayer/Bios.h
mv Source/Core/design.h Source/Core/Design.h
mv Source/Gui/toolbar.h Source/Core/Toolbar.h
in Source/HwLayer/ArmM3/src/interrupt.c use interrupt.h not Interrupt.h
in Source/HwLayer/ArmM3/src/startup.c use interrupt.h not Interrupt.h
in Source/HwLayer/ArmM3/src/cbios.cpp use BIOS.h not bios.h (line 5)
You also need new versions of the common/build.mk and arm_linux/Makefile files. You can see I changed quite a bit of stuff especially in build.mk.
I prefer github mainly because I’m trying to learn to use git. I hate svn but like cvs.
UPDATE: I found a way to eliminate the need to change the .lds files. New updates2.zip file.
updates2.zip (1.39 KB)
