Hi!
Using the 48k 6 channels firmware, the audio playback quality is degraded as soon as I start capturing.
[code]
SEEED ReSpeaker 4 Mic Array (UAC1.0) at usb-3f980000.usb-1.1.3, full speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S24_3LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 48000, 48000, 48000
Capture:
Status: Stop
Interface 2
Altset 1
Format: S16_LE
Channels: 6
Endpoint: 2 IN (ASYNC)
[/code]
Using usbtop, I can confirm that the USB bandwidth is nowhere near its max capacity (< 1MB/s).
Your setup is identical to mine but I am not able to get a clear audio playback during capture.
Here is what I do :
Session 1:
</s>aplay loop-test.wav -Dplughw:CARD=ArrayUAC10 -vv<e>
Stdout:
</s><i>
</i>Playing WAVE 'loop-test.wav' : Signed 24 bit Little Endian in 3bytes, Rate 48000 Hz, Stereo
Plug PCM: Hardware PCM card 1 'ReSpeaker 4 Mic Array (UAC1.0)' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : S24_3LE
subformat : STD
channels : 2
rate : 48000
exact rate : 48000 (48000/1)
msbits : 24
buffer_size : 24000
period_size : 6000
period_time : 125000
tstamp_mode : NONE
tstamp_type : MONOTONIC
period_step : 1
avail_min : 6000
period_event : 0
start_threshold : 24000
stop_threshold : 24000
silence_threshold: 0
silence_size : 0
boundary : 1572864000
appl_ptr : 0
hw_ptr : 0
<e>
Audio is clear. Then I start the capture in another session.
Session 2:
</s>arecord -Dhw:CARD=ArrayUAC10 mic.wav -c 6 -r 48000 -f S16_LE -vv<e>
Stdout:
</s><i>
</i>Recording WAVE 'mic.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Channels 6
Its setup is:
stream : CAPTURE
format : S16_LE
subformat : STD
channels : 6
rate : 48000
msbits : 16
buffer_size : 24000
period_size : 6000
tstamp_mode : NONE
period_step : 1
avail_min : 6000
period_event : 0
start_threshold : 1
silence_size : 0
appl_ptr : 0
hw_ptr : 0
<e>
Audio is degraded as soon as arecord starts capturing.
See the Audacity capture: https://we.tl/t-xi2h2gJpZZ
I have no clue why… Hope this helps your software engineers identify the cause. Tell me if you need more info.
Thanks again for your help.
