How to Use Sensecap M1 as LoRaWAN Gateway?
Hello, good morning.
I want to use SenseCAP M1 as a low-cost gateway.
Inn the attached image, SenseCAP M1 can be used as a LoRaWAN Gateway. I want to send data from the sensor to the gateway using LoRa which then from the gateway will be sent to the helium console, how do you configure it ?
Thank you…
