As the subject, when I run "python /home/respeaker/respeakerd/clients/Python/demo_respeaker_v2_vep_alexa_with_light.py", it shows "INFO:respeakerd_client:Start to connect to the socket: /tmp/respeakerd.sock ...
ERROR:respeakerd_client:Error when connect to the socket: [Errno 2] No such file or directory", how to resove this problem?
Moderators: lily.li, violet, salmanfarisvp, seth.welday
- Pre-kindergarten
- Staff
Re: respeakerd_client:Error when connect to the socket
Hi Hu,
We try to simulate the issue, but we do not see the error. Do you see any error during excuting "curl https://raw.githubusercontent.com/respe ... ll.sh|bash"? Please use the latest image 0610 from onedriver. please let us know if the issue is not solved. thanks.
Seeed techsupport team
Bill
Bill
- Pre-kindergarten
ERROR:respeakerd_client:Error when connect to the socket: [Errno 111] Connection refused
I get the same problem
The root cause is that you do not run the respeakerd. you have to open another terminal to run the respeakerd, then run the python code. thanks.
respeaker@v2:~$ sudo systemctl start respeakerd
respeaker@v2:~$ sudo journalctl -f -u respeakerd
