my question is. ¿How can i change default apn for connect to internet?
my apn parameters are:
APN: ac.vodafone.es
USER: vodafone
PASS: vodafone
I don't have a proxy.
Regards.
David.
change APN for spain
Re: change APN for spain
Modify the define statements in the 'https.cpp' file.
located here...
Arduino_IDE_for_RePhone-master\hardware\arduino\mtk\libraries\Network_https\utility
located here...
Ok,
but in tghe struct vm_gsm_gprs_apn_info_t not exists parameters like:
-user without proxy
-pass
-user without proxy
-pass
Are you working Arduino or Eclipse IDE?
I'm using Eclipse and I've verified configure my APN sucessfully.
In case:
In case:
Code: Select all
#define USING_PROXY VM_FALSE /* Whether your SIM uses proxy */
#define PROXY_ADDRESS "" /* The proxy address */
#define PROXY_PORT /* The proxy port */
void set_custom_apn(void)
vm_gsm_gprs_apn_info_t apn_info;
memset(&apn_info, 0, sizeof(apn_info));
strcpy(apn_info.apn, "ac.vodafone.es"); //I think that this field is optional
strcpy(apn_info.proxy_username, "vodafone");
strcpy(apn_info.proxy_password, "vodafone");
vm_gsm_gprs_set_customized_apn_info(&apn_info);
