Iron tip for surface mount components ?
General information
vincen
Post by vincen » Sat Jun 08, 2019 5:32 pm
Hi
Going to pass an order from Seeed for different stuffs (PCB, respeaker,...) and wanted to take profit to order a good iron solder kit for CMS/surface mount components (I'm based in Europe). What would you advice ? Is it me or none of models proposed by Seeed are efficient for that ? tips look too large !
Thanks for advices,
Vincèn
User avatar
salmanfarisvp
Kindergarten
Kindergarten
Which products/projects are your favorite?: Linklt One , BeagleBone Green , ReSpaker
Contact:
Re: Iron tip for surface mount components ?
Post by salmanfarisvp » Fri Jun 14, 2019 7:46 pm
Thank You :) .
vincen
Post by vincen » Sat Jun 15, 2019 9:45 pm
Hi Vincen ,
for the SMD components check these pointy tips
Thanks for the good links unhappy both are out of stock :( I wanted to order both with that soldering iron https://www.seeedstudio.com/Mini-Solder ... -2565.html but only the iron is avalaible :cry:
User avatar
salmanfarisvp
Kindergarten
Kindergarten
Contact:
Post by salmanfarisvp » Wed Jun 19, 2019 9:30 pm
Hi , Do check now It's avilable. Mini Soldering Iron - Europe Standard (Shape-BC2) : https://www.seeedstudio.com/Mini-Solder ... -2565.html
Thank You :) .
