respeakerd_client:Error when connect to the socket
miaoxiaohu
Post by miaoxiaohu » Fri Jun 22, 2018 9:20 pm
As the subject, when I run "python /home/respeaker/respeakerd/clients/Python/demo_respeaker_v2_vep_alexa_with_light.py", it shows "INFO:respeakerd_client:Start to connect to the socket: /tmp/respeakerd.sock ...
ERROR:respeakerd_client:Error when connect to the socket: [Errno 2] No such file or directory", how to resove this problem?
hong.jiang
Staff
Staff
Re: respeakerd_client:Error when connect to the socket
Post by hong.jiang » Thu Jun 28, 2018 2:38 pm
Hi Hu,
We try to simulate the issue, but we do not see the error. Do you see any error during excuting "curl https://raw.githubusercontent.com/respe ... ll.sh|bash"? Please use the latest image 0610 from onedriver. please let us know if the issue is not solved. thanks.
Seeed techsupport team
Bill
wangpenghao
Post by wangpenghao » Fri Jan 18, 2019 11:03 pm
ERROR:respeakerd_client:Error when connect to the socket: [Errno 111] Connection refused
I get the same problem
bill.yu
Junior-7
Junior-7
Post by bill.yu » Tue Jan 29, 2019 6:08 pm
The root cause is that you do not run the respeakerd. you have to open another terminal to run the respeakerd, then run the python code. thanks.
respeaker@v2:~$ sudo systemctl start respeakerd
respeaker@v2:~$ sudo journalctl -f -u respeakerd
