Help with Grove Serial RF Pro
Hi all,
I am starting on the arduino world, and i have a problem with my first project.
I´ve built an hygrostat with the humidity & temp sensor (no problems with that) for my cigars, but i want to send Hum & Temp info to my oregon scientific
Reading about how to do it, i thought the Serial RF Pro will be the right component, but i find two problems:
  • First and most important, i can´t manage to configure or check the parameters through the instructions provided in the wiki, anyone has an example on the code needed? i couldn´t find any example.
  • As indicated by Seed, the module standard frequency is set to 433ghz, but i can’t receive any info from my oregon scientific sensors. On the same way, any reference or code example, will be very welcome.
Thank you for your Help !!
Anybody?
I can´t believe i am the only beginner with problems on this :open_mouth: … Come on !!
Is anybody using this this module for anything? anything could help… Otherwise i will try with sparkfun parts.
Thanks :slight_smile: :slight_smile:
Features:
seeedstudio.com/wiki/Grove_- … troduction
Example:
seeedstudio.com/wiki/Grove_- … rogramming
Config:
seeedstudio.com/wiki/Grove_- … es_Summary
Your choice is good. Very nice project for beginner :wink:
I use RFBee with XBee Carrier and Humi/Temp sensor for my Humidor. Its LiPo powered (no wires :wink: and very small but the RFBee does not runs out of the box as standalone device.
