can not find the seeed-2mic-voicecard
Moderators: violet, seth.welday
1515613347
Post by 1515613347 » Tue Jun 05, 2018 12:55 pm
hi~
i ran the followed code in my raspberry
Code: Select all
sudo apt-get update
sudo apt-get upgrade
git clone https://github.com/respeaker/seeed-voicecard.git
cd seeed-voicecard
sudo ./install.sh
reboot
however, when i run
Code: Select all
aplay -l
i can not find card 1: seeed2micvoicec [seeed-2mic-voicecard], device 0: bcm2835-i2s-wm8960-hifi wm8960-hifi-0 []
Subdevices: 1/1
here is my result:
Code: Select all
pi@raspberrypi:~/dingdang $ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
  Subdevices: 7/7
  Subdevice #0: subdevice #0
  Subdevice #1: subdevice #1
  Subdevice #2: subdevice #2
  Subdevice #3: subdevice #3
  Subdevice #4: subdevice #4
  Subdevice #5: subdevice #5
  Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
  Subdevices: 1/1
pi@raspberrypi:~/dingdang $ arecord -l
**** List of CAPTURE Hardware Devices ****
i don not know whether this ReSpeaker 2-Mics Pi HAT can work, how can i test it or solve this prolem.
thx
bill.yu
Elementary-2
Elementary-2
Re: can not find the seeed-2mic-voicecard
Post by bill.yu » Tue Jun 05, 2018 1:53 pm
Dear Customer, We suspect some error during sudo ./install.sh. We suggest change to your http://www.raspbian.org/RaspbianMirrors and try it again. If it still does not work, we upload a 4 mic image in https://drive.google.com/open?id=15yEZE ... hV4OVimQ_7 and it works with 2 mic as well. thanks.
Seeed TechSupport Team
Bill
rgall
Post by rgall » Wed Jun 06, 2018 8:05 pm
I have the same issue. What could be in that rar file its 1.7GB packed and over 7GB unpacked?
hong.jiang
Staff
Staff
Post by hong.jiang » Mon Jun 11, 2018 10:46 am
Dear customer, we installed the drivers and then build the image. do you have any issue with the image? thanks.
Seeed techsupport Team
Bill
spock
Post by spock » Wed Jun 13, 2018 12:25 am
Hi !
I got the same error and I changed operating system from Ver.20180217 to Ver.20171129. I could solve this problem.
But finally another symptom appeared. I think two microphones are not react.
And another question...
Which type should I register this device to Google Assistant SDK ?
Please teach. Thank you.
hong.jiang
Staff
Staff
Post by hong.jiang » Thu Jun 28, 2018 2:59 pm
Hi Spock,
We use the RASPBIAN STRETCH WITH DESKTOP 2018.4.18 image for the testing. it works well. please download it from https://www.raspberrypi.org/downloads/raspbian/. Please try and let us know if any issue.
Please follow https://developers.google.com/assistant ... ev-project and click Image
thanks
Seeed techsupport team
Bill
frederic.wets
Post by frederic.wets » Thu Jun 28, 2018 8:13 pm
Hi There,
I've the same issue, using your binary to run.
I'm having a low voltage alert, do you think it can be linked ?
However, I'm using Rpi 3B+, camera V2, 7" official display, and official power supply.
Many thanks.
Fred
hong.jiang
Staff
Staff
Post by hong.jiang » Mon Jul 02, 2018 1:47 pm
Hi Fred
If you have the power drop, please plug a usb power cable to 2 mics pi hat USB port. it is designed if we connect the speaker on the Pi HAT. But i do not think errors are related with power drop. We use the RASPBIAN STRETCH WITH DESKTOP 2018.4.18 image for the testing. it works well. please download it from https://www.raspberrypi.org/downloads/raspbian/. please copy all the logs during ./install.sh and we can see if it is related with driver installation. thanks.
Bill
