flow mesurement
Moderators: lily.li, violet, carmen.zheng
noenoe
flow mesurement
Post by noenoe » Tue Jan 19, 2010 3:14 am
Im am looking for a fairly cheap and easy way to messure waterflow, ie. from the tap or in the shower or the gardenhose.
Could be with a rotating device in tube giving a detectable signal each 10 milli liter.
So far I havent been able to spto anything but heavy industrial grade or simple flow/no flow by picking up vibrations with a piezo element. The last is not sufficient as the flowrate might vary. Any idea if it is out there at a reasonable price?
/Noenoe
deki_mg
Re: flow mesurement
Post by deki_mg » Sat Mar 20, 2010 3:22 pm
This really is a good question, I'm interested in same thing, though I could use a bit better resolution (pulse each 5ml)...
If you find out anythinhing, let me know.
cheers
User avatar
esp
Elementary-3
Elementary-3
Re: flow mesurement
Post by esp » Fri May 21, 2010 10:21 am
We finally sourced some samples now, will be listed in a few days. Thank you!
User avatar
makersworkbench
Contact:
Re: flow mesurement
Post by makersworkbench » Sun Aug 29, 2010 5:35 am
The flow meter Seeed already carries can do this quite easy. I will post the arduino sketch for this tonight.
User avatar
makersworkbench
Contact:
Re: flow mesurement
Post by makersworkbench » Sun Aug 29, 2010 3:23 pm
MikeCash
Which products/projects are your favorite?: wireless, stalker
Re: flow mesurement
Post by MikeCash » Tue Sep 13, 2011 9:56 pm
Waterflow Sensor is awesome! Is there anything available with a larger thready (2" or 3") with high flow rates (1000 litres per minute)?
