Silk screen drc errors
Moderators: lily.li, violet, carmen.zheng
solexious
Post by solexious » Sun Oct 04, 2009 2:14 am
When running checks on my board I have fixed all errors, apart from I get lots of errors about silk screens on top of solder areas.
I'm used to other prototyping services just not printing the silk screen there with no need to remove it from my design. Do I need to do this with you?
Also how much ish would shipping be to the uk for the 10 propaganda 10x10 boards?
Thank you
sol
solexious
Re: Silk screen drc errors
Post by solexious » Wed Oct 07, 2009 8:33 pm
Hello?
solexious
Post by solexious » Tue Oct 20, 2009 3:49 pm
Any one out there?
User avatar
atomriot
Elementary-1
Elementary-1
Post by atomriot » Wed Oct 21, 2009 12:30 am
thats weird that you have not gotten a reply yet. try PM'ing ESP or Albert.Miao or Seeedstudio-Fan with your question.
they must be pretty busy with the DSO Nano and rainbowuino carnival stuff.
solexious
Post by solexious » Tue Nov 03, 2009 8:21 am
Done with still no reply :(
You out there admin's?
sol
User avatar
Albert.Miao
Elementary-2
Elementary-2
Post by Albert.Miao » Thu Nov 05, 2009 11:13 am
Hi guys,
Much sorry for reply so late.
Please find our eagle cam tool for generating the gerbers:
SeeedStudio_gerber_drill_091105.zip
(1.09 KiB) Downloaded 342 times
And design rule:
SeeedStudio_rule_no_angle_090911.zip
(1.01 KiB) Downloaded 318 times
Albert
solexious
Post by solexious » Sun Nov 08, 2009 12:10 pm
That doesn't answer the question but I have since emailed you.
Sol
PC_fun
Post by PC_fun » Fri Nov 27, 2009 9:56 am
And what did you end up finding out. Is it okay for the silk screen to overlap the soldering pads, or holes for that matter?
I am currently putting the finishing touches to a project which I am very soon going to design the prototype PCB's for. But I know from past projects, that some of the footprints I need, have parts of the silk screen running over solder pads and holes, since that doesn’t matter at the manufacturers I normally have used. So if it isn’t allowed in designs for manufacturing at SeeedStudio I might as well redesign the footprints before making or sending the PCB design, instead of getting it turned down.
So my question is: Is it okay for an silk screen line to cross a soldering pad or a hole? :?:
Best regards and thanks in advance for your answer
PC_fun
Post by PC_fun » Fri Nov 27, 2009 10:28 pm
Hello, anyone out there?
User avatar
Albert.Miao
Elementary-2
Elementary-2
Post by Albert.Miao » Tue Dec 01, 2009 9:18 am
Hi PC_fun,
Much sorry for replying so late.
"So my question is: Is it okay for an silk screen line to cross a soldering pad or a hole?"
Yes, No problem.
The silkscreen on the pad and cross the hole will not print well.
Albert
