Approving DRC errors okay?
Moderators: lily.li, violet, carmen.zheng
jeremy.xiao725
Which products/projects are your favorite?: Seeeduino V2.21
Post by jeremy.xiao725 » Sat Nov 03, 2012 12:09 am
In Eagle I have traces from two different net classes that I want to connect. I've tried simply connecting the traces, and I've tried using a solder jumper part. In both cases, the project fails the DRC check because the components are too close to one another. Of course, this is okay with me. They're supposed to be close (overlapping!). Can I just approve this DRC error, create the gerber files, and send them off?
Thanks,
Jeremy
dingding
Staff
Staff
Which products/projects are your favorite?: DSO
Re: Approving DRC errors okay?
Post by dingding » Wed Nov 07, 2012 9:22 am
yes, you can ingore it.
i suggest you can set the clearance of same signals as 0mil in DRC rule, the errors will be disappeared.
have a nice day!
dingding
catherine12297
Post by catherine12297 » Fri Dec 28, 2018 3:03 pm
indeed, you can ingore it.
I recommend you can set the leeway of same flags as 0mil in DRC rule, the blunders will be vanished.
have a pleasant day!
dingding
