Page 1 of 1
PCBs larger than 20cm
Posted: Thu Oct 20, 2011 7:55 am
by nicholas4
I have a PCB, 211x135mm that I would like to have made. The largest size you offer for your service is 20x20cm. (It's large because it holds several big LED 7-segment displays, for a clock).
Can you make this board and if so how much for 10?
Thank you.
Nicholas
Re: PCBs larger than 20cm
Posted: Mon Oct 24, 2011 11:49 am
by liao
Yes, we cand help to make. The reason we don't offer the service for size over 20cm * 20cm is because the big size is easy to break during the fabrication. However, I think your design is Ok to make. You can buy a 20cm *15cm and send the files to us.
Posted: Tue Jan 17, 2012 11:27 am
by nicholas4
Thanks, it worked out fine.
Posted: Wed Feb 29, 2012 12:45 pm
by frob
Hi, i have a PCB design also a bit larger - 21.6 x 21.6 cm can is it still possible to do ?
Posted: Wed Feb 29, 2012 3:26 pm
by liao
frob wrote:Hi, i have a PCB design also a bit larger - 21.6 x 21.6 cm can is it still possible to do ?
You can send your designs to pcb@seeedstudio.com before placing the order. And we will evaluate and get back to you if we can do it.
