Respeaker 2 mic on max2play distribution
I try to install a respeaker 2mic on a max2play distribution.
but I meet a problem with the classical instructions to install the respeaker.
In fact, I can’t do the “Apt-get upgrade” because it change completely the architecture of the max2play installation.
and when I tried to install it without the “Apt-get upgrade” i have this message
Setting up read-edid (3.0.2-1) …
Setting up i2c-tools (3.1.2-3) …
Setting up libasound2-plugins:armhf (1.1.1-1) …
Setting up dkms (2.3-2) …
Processing triggers for man-db (2.7.6.1-2) …
Creating symlink /var/lib/dkms/seeed-voicecard/0.3/source ->
/usr/src/seeed-voicecard-0.3
DKMS: add completed.
Error! echo
Your kernel headers for kernel 4.14.76+ cannot be found at
/lib/modules/4.14.76+/build or /lib/modules/4.14.76+/source.
Error! echo
Your kernel headers for kernel 4.14.76-v7+ cannot be found at
/lib/modules/4.14.76-v7+/build or /lib/modules/4.14.76-v7+/source.
Kernel preparation unnecessary for this kernel. Skipping…
Building module:
cleaning build area…
make -j4 KERNELRELEASE=4.14.79+ -C /lib/modules/4.14.79+/build M=/var/lib/dkms/s eeed-voicecard/0.3/build…
DKMS: build completed.
Building module:
make -j4 KERNELRELEASE=4.14.79-v7+ -C /lib/modules/4.14.79-v7+/build M=/var/lib/ dkms/seeed-voicecard/0.3/build…
Error! echo
Error! echo
and it finally tell
DKMS: install completed.
setup git config
git init
Initialized empty Git repository in /etc/voicecard/.git/
git add --all
git commit -m “origin configures”
[master (root-commit) f84babc] origin configures
7 files changed, 1476 insertions(+)
create mode 100644 ac108_6mic.state
create mode 100644 ac108_asound.state
create mode 100644 asound_2mic.conf
create mode 100644 asound_4mic.conf
create mode 100644 asound_6mic.conf
create mode 100644 dkms.conf
create mode 100644 wm8960_asound.state
Created symlink /etc/systemd/system/sysinit.target.wants/seeed-voicecard.service → /lib/systemd/system/seeed-voicecard.service.
Please reboot your raspberry pi to apply all settings
Enjoy!
but I don’t find it on asound
could you help me ?
