LED control on Mic Array v2
ningma97
Post by ningma97 » Fri Sep 21, 2018 9:49 pm
I am able to change the colour of the LED ring on the Mic Array v2, but for some reason changing the brightness has no effect. I also can't control individual LEDs using the "pixel_ring.write(6, data)" method.
Any idea how to change the brightness?
Many thanks
Ning
bill.yu
Junior-7
Junior-7
Re: LED control on Mic Array v2
Post by bill.yu » Wed Sep 26, 2018 4:50 pm
HI Ning
please try below code and modify the 0x01 to [set brightness, range: 0x00~0x1F]. thanks.
Code: Select all
import time
from pixel_ring import pixel_ring
if __name__ == '__main__':
    pixel_ring.change_pattern('echo')
    while True:
        try:
            pixel_ring.set_brightness(0x01)
            pixel_ring.think()
        except KeyboardInterrupt:
            break
    pixel_ring.off()
    time.sleep(1)
ningma97
Post by ningma97 » Thu Sep 27, 2018 7:54 pm
Thank you Bill. I got it working in the end. The brightness setting seems to only work if I change the LED colour, otherwise there is no effect.
Best
Ning
