how to do volume control of re-speaker mic array 2.0
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Mon Nov 05, 2018 3:19 pm
how to do volume control of re-speaker mic array 2.0 ?? I want to use it with RPI board also i am not able to use alsamixer as per my application..
Please answer asap.
Seeed Tech Support
Post by Seeed Tech Support » Wed Nov 07, 2018 5:49 pm
please install pluseaudio. after installation, please reboot. thanks.
sudo apt-get install pulseaudio
best rgds
Bill
For any technical support, please post your questions to our forum.
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Thu Nov 15, 2018 1:05 pm
Thanks for the information.
One more question How to disable the all MICs in Mic Array from external
control button (like alexa, google home ) with mute button functionality.
Please let me know asap.
Seeed Tech Support
Post by Seeed Tech Support » Fri Nov 16, 2018 10:29 am
Hi,Please try below commands to mute/unmute the mics. i tested it and it works well. you can read the button signal and then use below command to mute the mics. for more info, please refer to https://wiki.archlinux.org/index.php/PulseAudio . thanks.
To mute/unmute the microphone:
$ pactl set-source-mute 1 toggle
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Tue Dec 04, 2018 4:48 pm
Sorry but i forgot to add one point here is that you have removed speaker
connector and connection in rev 2 . So, Can i able to use that connection
for speaker from rev 2 mic array ??
Seeed Tech Support
Post by Seeed Tech Support » Tue Dec 04, 2018 5:02 pm
Hi
MahammadIrfan,
You can connect the speaker to item 5, 3.5mm audio jack. thanks.
best rgds
Bill
Anonymous
Kindergarten
Kindergarten
Post by Anonymous » Tue Dec 04, 2018 5:48 pm
Dear Bill,
I know that thanks for the info. my question When i setup external speaker
( from Board to Board connector) and at the same time from headset (3.5 mm
jack) . so my application is that when I insert headset into 3.5mm jack of
mic array, speaker should be mute and all sound from Headset only which was
not happen as i have checked.
Is it possible ?? I want to make an application like in mobile phone when
we play song through headphones sound stop from speaker and when we remove
headset sound play from speaker. Please help me out as my project is at
critical stage.
2nd may I know the Manufacturer Part Number of the Audio jack you have used
in design of Mic array so to check my application will work or not ??
Seeed Tech Support
Post by Seeed Tech Support » Tue Dec 04, 2018 6:33 pm
Hi  Sorry, I do not have a good answer for the first question.For the second one, I attached the audio jack spec. thanks.best rgdsBill
Seeed Tech Support
Post by Seeed Tech Support » Wed Dec 05, 2018 5:16 pm
Hi,I do not have a good solution as well. thanks for understanding. best rgdsBill
Seeed Tech Support
Post by Seeed Tech Support » Wed Jan 02, 2019 3:33 pm
1. can I directly solder speaker to HP_L and HP_R of board to board
connector to Speaker like 1 to 5 W power.
I  use the 450050 speaker, the sound is quite low, but you can hear the voice.
2. Can I make setup that play both external speaker from HP_L and HP_R of
board to board connector and Headphone from 3.5mm jack and at a time only
one will work.
Yes, you can hear both of them, but the Speaker connect HP_L and HP_R of board is quite low sound. thanks.
Merry Christmas  and Happy New Year.best rgdsBill
