I’m using the latest Debian version on Respeaker Core v2.
I’m recording with the sox tools over alsa (I removed pulse audio).
I’m using the simple .asoundrc file:
pcm.!default {
type asym
capture.pcm “mic”
playback.pcm “speaker”
pcm.mic {
type plug
slave {
pcm “hw:seeed8micvoicec,0”
rate 16000
pcm.speaker {
type plug
slave {
pcm “hw:seeed8micvoicec,1”
channels 2
I was wondering if with this configuration, I record with beamforming feature from the Respeaker
Or do I have use a more complicated .asoundrc or even the librespeaker library to benefit from some beamforming features?
Thanks for your help
For the beam-forming function, you have to use librespeaker function to enable this function. you can refer to <LINK_TEXT text=“http://wiki.seeedstudio.com/ReSpeaker_C … io-process”>http://wiki.seeedstudio.com/ReSpeaker_Core_v2.0/#librespeaker-aduio-process</LINK_TEXT> thanks.
