Page 1 of 1
Wio with UART grove module doesnt start when usb plugged in
Posted: Sat Jan 12, 2019 11:44 pm
by email4kai
I have a wio tracker with grove uart bluetooth module (HM11) attached.
The tracker script doesnt start, if I plug the usb power cord. I must do a reset, bevor the script starts. I'ts only when uart module is attached.
I have made a test script, with only led use. It has no effect, if I use the SerialUSB/DBG Communication or not.
Any hints or suggestions ?
Kind regards
Kai
Re: Wio with UART grove module doesnt start when usb plugged in
Posted: Thu May 09, 2019 9:23 am
by bill.yu
Hi Kai
1. For the wio tracker, it includes the Bluetooth functions.
http://wiki.seeedstudio.com/wio_gps_boa ... connection
2. The wio tracker uses the SerialDBG for Grove uart and SerialUSB for serial print on COM port. If you add the SerialUSB in your code, you have to open the COM port, or else, it will stuck at that line. Here is the example for Grove-UART. The Grove UART power supply is cut off by default. You have to pull pin12 high to enable the power supply. thanks.
Code: Select all
#define GrovePowerPin   12
  pinMode(GrovePowerPin, OUTPUT);
  digitalWrite(GrovePowerPin, HIGH);    //power Grove
  //SerialUSB.begin(115200);
  SerialDBG.begin(115200);    //set Grove UART baud rate 115200
void loop() {
  //SerialUSB.println("Grove UART is sending message");
  SerialDBG.println("This is Grove UART");
  delay(1000);
