How to make a momentary pulse
Simplify IoT Development.
garystofer
Post by garystofer » Fri Apr 29, 2016 1:33 pm
I'm trying to use a digital pin for a momentary signal, but I can't find anything in the API that would let me do that. I would like a way to raise a signal which then automatically resets to zero after a certain time which I define as an argument in the call.
Can you point me at documentation or code that would let me implement such a feature if it doesn't already exist.
Gary
Wio
Re: How to make a momentary pulse
Post by Wio » Mon May 02, 2016 2:40 am
Which times do you plan?
garystofer
Post by garystofer » Tue May 03, 2016 10:28 am
A range between 100 ms and 10 seconds would be sufficient for what I'm planning on using it. Basically trying to simulate a push button press.
teng.wang
Post by teng.wang » Wed May 04, 2016 11:44 am
The Grove-Button have a event api(websocket).
You can use it to check the button is press or not.
garystofer
Post by garystofer » Thu May 05, 2016 4:39 am
No, you don't understand. I don't want to check if a button is pressed or not, I want a means of making a self resetting signal out on the WIO. A digital pin that autonomously clears itself after a given time, to be controlled with a simple DO button interface. No feedback -- no handshaking -- no event .
Gary
